Refrain from deleting my stock replies
Then please refrain from deleting my stock replies where they were already posted or changing them in future without permission or agreement.
I am still in the progress of reverting them back to more of the original intent.
Please stick to your own adaptations / derivatives and use your own name instead of impersonating me. Feel free to add extra derivative's using your own name's in your own posts.
That is what a derivative is !
Your use of "system" and "impersonation" is also a concern when it comes to alterations.
Would like to see flags available to all users so they can check what has been changed and agree or revert without punitive measures.
Interesting I believe it was you a few years back that told me not to use them.
Could be.
However a lot of things changed.
They became exceptionally useful and were even implemented in SMF under my watch.
Then transplanted to Discourse.
And changed on many hundreds of my posts without without due notice or agreement by a broken rung.
I have had several answers changed, I just ignore it as there is nothing I can do. The thing that bugs me the most is the op changes his question after I have answered making my answer wrong then my answer gets called. I am now sometimes quoting part of his question. You have always had great answers with good material and they show a lot of research, I really appreciate that. I have had more years experience then many of the users have lived. Anyhow do not let it bother you keep up the good work, I know there are many more that appreciate it. If you celebrate Have a very Happy Easter!
Well it seems the culling of helpful information and links continues.
A lot of the basic section readme's have been culled or cut loose.
To be replaced by
Many had product specific information.
Well it seems the aherm "SYSTEM" has decided it no longer likes the boilerplate help.
Would be nice to know who reported it and which "staff" member decided it was not allowed ?
Flagged post removed by staff
Apr 7
1 / 1
Apr 7
4m
system
4mpost #1
Hello,
This is an automated message from Arduino Forum to let you know that your post was removed.
Your post was flagged as off-topic: the community feels it is not a good fit for the topic, as currently defined by the title and the first post.
This post was flagged by the community and a staff member opted to remove it.
Then there was this.
Please take a few moments to Learn and Use The Forum
[How to get the best out of this forum](https://forum.arduino.cc/t/how-to-get-the-best-out-of-this-forum/679966) [Installation & Troubleshooting](https://forum.arduino.cc/c/using-arduino/installation-troubleshooting/18)
Hello, Welcome to the Arduino Forum. This guide explains how to get the best out of this forum. Please read and follow the instructions below. Being new here you might think this is having rules for the sake of rules, but that is not the case. If you don’t follow the guidelines all that happens is there is a long exchange of posts while we try to get you to tell us what we need in order to help you, which is frustrating for you and frustrating for us. The people who try to help with your pro…
It will help you get the very best out of the forum in the future.
* Your OS and version can be valuable information, please include it along with extra security you are using. Antivirus etc.
* Always list the version of the IDE you are using and the board version if applicable.
* Use quote or add error messages as an attachment NOT a picture.
* How to [insert an image](https://forum.arduino.cc/t/a-thread-with-tips-and-tricks-for-the-new-discourse-based-arduino-forum/849827/3) into your post. ( Thanks [sterretje](https://forum.arduino.cc/u/sterretje) )
* Add your sketch where applicable but please use CODE TAGS
* Add a SCHEMATIC were needed even if it is hand drawn
* Add working links to any specific hardware as needed (**NOT** links to similar items)
* Remember that the people trying to help cannot see your problem so give as much information as you can
**COMMON ISSUES**
* Ensure you have **FULLY** inserted the USB cables.
* Check you have a [COMMON GROUND](https://forum.arduino.cc/index.php?topic=653831.msg4406618#msg4406618) where required. ( Thanks [Perry](https://forum.arduino.cc/u/perry))
* Where possible use USB 2.0 ports or a USB 2.0 POWERED HUB to rule out USB 3.0 issues.
* Try other computers where possible.
* Try other USB leads where possible.
* You may not have the correct driver installed. [CH340/341](http://www.wch.cn/download/CH341SER_EXE.html) or [CP2102](https://www.silabs.com/products/development-tools/software/usb-to-uart-bridge-vcp-drivers) or FT232 [VCP Drivers - FTDI](https://ftdichip.com/drivers/vcp-drivers/)
* There may be a problem with the board check or remove your wiring first.
* Remove any items connected to pins 0 and 1.
**COMPUTER RELATED**
* Close any other serial programs before opening the IDE.
* Ensure you turn off any additional security / antivirus just to test.
* There may be a problem with the PC try RESTARTING it.
* You may be selecting the wrong COM port.
* Avoid cloud/network based installations where possible OR ensure your Network/Cloud software is RUNNING.
* Clear your browsers CACHE.
* Close the IDE before using any other serial programs.
* Preferably install IDE’s as ADMINISTRATOR or your OS equivalent
**ARDUINO SPECIFIC BOARDS**
* CH340/341 based clones do not report useful information to the “get board info” button.
* NANO (Old Types) some require you to use the OLD BOOTLOADER option.
* NANO (**ALL Types**) See the [specific sections](https://forum.arduino.cc/index.php?board=135.0) lower in the forum.
* NANO (**NEW Types**) [Install your board CORE’s.](https://forum.arduino.cc/index.php?topic=642505.0)
* Unless using EXTERNAL PROGRAMMERS please leave the IDE selection at default “AVRISP mkII”.
* Boards using a MICRO usb connector need a cable that is both DATA and CHARGE. Many are CHARGE ONLY.
**CREATE editor install locations.**
* On macOs ~/Applications/ArduinoCreateAgent-1.1/ArduinoCreateAgent.app/Contents/MacOS/config.ini
* On Linux ~/ArduinoCreateAgent-1.1/config.ini
* On Windows C:\Users[your user]\AppData\Roaming\ArduinoCreateAgent-1.1
***Performing the above actions may help resolve your problem without further help.***
**Language problem ?**
**Try a language closer to your native language:**
* [中文 (Chinese)](https://forum.arduino.cc/index.php?board=99.0)
* [Deutsch - German](https://forum.arduino.cc/index.php?board=31.0)
* [Español - Spanish](https://forum.arduino.cc/index.php?board=32.0)
* [Français - French](https://forum.arduino.cc/index.php?board=33.0)
* [অসমীয়া, বাংলা, बड़ो - India](https://forum.arduino.cc/index.php?board=82.0)
* [Italiano - Italian](https://forum.arduino.cc/index.php?board=34.0)
* [Nederlands - Dutch](https://forum.arduino.cc/index.php?board=77.0)
* [Portugues - Portuguese](https://forum.arduino.cc/index.php?board=35.0)
* [Россия - Russia](https://forum.arduino.cc/index.php?board=120.0)
* [Scandinavia Swedish, Suomi - Finnish, Norsk - Norwegian](https://forum.arduino.cc/index.php?board=36.0)
**Thanks to all those who helped and added to this list.**
Please review our [community guidelines](https://forum.arduino.cc/guidelines) for details.
If users read that the questions would suffer a major cut as the answer would become apparent to them. Apparently it is important to keep the number of questions high.
