So, let's say I have a LiPo battery rated at 4200 mAh. I run it through a small converter to turn it into a USB power supply, stepping the voltage up to 5v.
Is the conversion of mAh proportional, like amperage? I.e. At 3.7 v, it will provide 4200 mAh at 420mA drain, but at 5V it'll only provide 3108 mAh at a 310 mA drain.
SHOW YOUR WORK WHEN POSTING CALCULSTION RESULTS ON THE FORUM.
This is an open source forum.
If you present your results, ww want everyone to understand how you obtained them. Your results may be wrong because you used 3.7 V instead of 4.2 V (NOT really sure abiut that. It may average out to the result you obtained.)
( it didn't require any rocket science to figure out you divided 3.7V by 5 V and multiplied 4200 mAh by the result.)
First of all, a 1S 4200 mAh lipo is 4.2V (charged) , .
and you can safelybdischarge it to 3.3 V. The discharge curve is nonlinear. It would require calculus to integrate the various currents at the decreasing voltage . I sucked at Calculus.
Do the math :
P = I x V
4.2 Ah x 4.2 V
= 17.64 Wh 4.2 Ah,(0.070 Aminutes for 60 minutes)
17.64Wh/5V =3.528 Ah (0.0588 Aminutes for 60 minutes)
Suppose your DC-DC converter is 95% effective (95% is high, if depends on the quality and often also on the amount of current).
Your LiPo battery is 3.0 (or 3.3) to 4.2V with 4200 mAh. Let's say an average of 3.7V. That is a total of 15.54 Wh. 95 percent of that is 14.76 Wh.
At 5V, that 14.76 Wh results into 2953 mAh (or 3108, with a 100% DC-DC converter).
So yes, at 5V you have 2953 (3108) mAh at 295 (310) mA drain.
While I was typing this, raschemmel already answered it, but I'm going to post it anyway.
ha, ha. Actually I' m watching the recorded Raptors@ Heat playoff game ( can you believe Duane Wade ?) while posting on the forum with my smartphone. I got food poisoning last night and have been recovering in bed all day. @OP,
See, even illness can't stop us ha, ha.
raschemmel:
Do the math :
P = I x V
4.2 Ah x 4.2 V
I used 3.7V because that's what the battery puts out on a full charge. I got it off of banggood, so it may not be a LiPo battery, it might be Li-Ion instead.
So:
4.2Ah * 3.7 V = 15.54 Wh
15.54 Wh / 5 V = 3.108 Ah
So my initial math gives me a correct(ish) answer without calculus, which I'm allergic to as well.
Then haven't used this kind of battery before. Put a meter on a charged battery and connect it to your load. It is not going to drop down to 3.7 V unless it's driving a motor.
Do you have a lipo charger ? Matbe that's your problem. EVEFY SINGLE LIPO I HAVE CHARGED IN 10 YEARS OF RC AIRCRAFT WAS 4.2V when the charger said it was "charged".
Well, what I'm saying is that I purchased a pair of batteries with a usb powered charging cradle from banggood in the 18650 kind of format/size. The posting SAID they were LiPo, but I begin to doubt that now.
A charged Lipo or Li-ion is 4.2V. Allthough they are sometimes only charged up to 3.95V to make them last longer for medical and military devices.
Could you give a link to that battery or make a photo of it ?
If you have accidently LiFePO4 batteries, then you can't use a charging circuit for Lipo or Li-ion batteries.
In the past, sometimes I had luck: the cheap LiFePO4 that I bought were very good. But I had a lot of trouble with bulged 12V Li-ion battery packs that were filled with cardboard.
Today I use good quality rechargeable NiMH AA and AAA (Eneloop / Panasonic) batteries and sometimes Li-ion or Lipo batteries, but only when they are good quality.
In the end, the good quality batteries are cheaper, because they last longer and don't give trouble.
rollerce:
In reality the 4.2Ah figure is 'optimistic' (4200mAh is a dumb way to say 4.2Ah devised by marketroids
to make the battery sound really bigggggg!)
Battery capacities are measured under the most favorable conditions possible (new battery, freshly over-charged, at a specific temperature and discharge rate).
Call your battery 3Ah, expect 2Ah at 5V over a reasonable number of charge cycles in. If you rely on
3.1Ah you'll be disappointed - no battery chemistry is anything like perfect, they all age significantly,
they all lose capacity much faster if abused (over, under charged, over current or over temperature).
If neither your DC-DC converter or battery pack has an under-voltage cutout, get a low-voltage alarm
for your system, or you'll probably ruin the battery pack the first time it discharges.
Probably this is what he's talking about, Cheap and quite popular in most chinese retail sites and on ebay. Not very efficient boost conversion, dunno about the efficiency of the charging module.
As for the battery, it may not be LiPo or the mentioned Capacity. I've seen 5000mAh chinese 18560 ultrafires that have only 1500mAh or less and fails after a few dozen charge cycles.
That's why I stick with my TP4056 module and.buys only original 18650s even if they are lower capacity than fake advertised ones.
I haven't seen any statement indicating the OP measured the battery voltage after charging. It remains unknown whether he has a real Lipo charger or something else.
What ( exactly) dies this mean:
"I used 3.7V because that's what the battery puts out on a full charge"
Theres no such thing as a 4.2 AH 18650 cell.
The best that currently exist are panasonic 18650 cells at 3.4 AH and they cost anywhere from $10 - $15 each.
Anything thats bigger is a fake , and there are lots of fakes coming from China.
Post a photo of the battery and the charging cradle and a link to the vendor site.
It appears your info about 4200 mAh may be incorrect or the battery type may not be lipo.
