Regarding project programming
Sir i am working on a project in which i use Arduino UNO for making my project. Where i use acceleration sensor, Pressure sensor(2) and ultrasonic sensors (2).
Sir please suggest me proper coding for my project.
vaibhav_bhavsar:
For a start the coding will depend on the exact make and model of each of those sensors. And if you do know that detail, you should find code (including perhaps a library with examples) for each.
Have you got that far?
The coding will also depend on what it is that you want to do with all these sensors. You'll need a more detailed specification than "a project where I use sensors". From what you've said so far you have a lot of inputs but no output.
Steve
look in the Project Hub here for similar projects
look in the examples in libraries
research arduino + pressure sensor + ultrasonic sensor
come back when you have a specific question that shows us you have done your homework.
