Regarding RTc
Can i glow my LED based on time set by RTC module,pls guide me through how to set time using RTC(DS1307) in my DUE board.
There’s an example in the DS1307RTC library’s “example” folder; it sets the RTC’s time to the time from your PC when you compiled and uploaded the sketch in the IDE.
//set the time to pc system time at compile time
//from the ds1307rtc library's examples
#include <Wire.h>
#include <Time.h>
#include <DS1307RTC.h>
const char *monthName[12] = {
  "Jan", "Feb", "Mar", "Apr", "May", "Jun",
  "Jul", "Aug", "Sep", "Oct", "Nov", "Dec"
tmElements_t tm;
  bool parse=false;
  bool config=false;
  // get the date and time the compiler was run
  if (getDate(__DATE__) && getTime(__TIME__)) {
    parse = true;
    // and configure the RTC with this info
    if (RTC.write(tm)) {
      config = true;
  while (!Serial) ; // wait for Arduino Serial Monitor
  delay(200);
  if (parse && config) {
    Serial.print("DS1307 configured Time=");
    Serial.print(__TIME__);
    Serial.print(", Date=");
    Serial.println(__DATE__);
  } else if (parse) {
    Serial.println("DS1307 Communication Error :-{");
    Serial.println("Please check your circuitry");
    Serial.print("Could not parse info from the compiler, Time=\"");
    Serial.print("\", Date=\"");
    Serial.print(__DATE__);
    Serial.println("\"");
bool getTime(const char *str)
  int Hour, Min, Sec;
  if (sscanf(str, "%d:%d:%d", &Hour, &Min, &Sec) != 3) return false;
  tm.Hour = Hour;
  tm.Minute = Min;
  tm.Second = Sec;
  return true;
bool getDate(const char *str)
  char Month[12];
  int Day, Year;
  uint8_t monthIndex;
  if (sscanf(str, "%s %d %d", Month, &Day, &Year) != 3) return false;
  for (monthIndex = 0; monthIndex < 12; monthIndex++) {
    if (strcmp(Month, monthName[monthIndex]) == 0) break;
  if (monthIndex >= 12) return false;
  tm.Day = Day;
  tm.Month = monthIndex + 1;
  tm.Year = CalendarYrToTm(Year);
  return true;
Arduino: 1.5.7 (Windows 8), Board: "Arduino Due (Programming Port)"
Build options changed, rebuilding all
In file included from sketch_oct01a.ino:6:0: C:\Program Files (x86)\Arduino\libraries\DS1307RTC/DS1307RTC.h:19:22: error: 'tmElements_t' has not been declared static bool read(tmElements_t &tm); ^ C:\Program Files (x86)\Arduino\libraries\DS1307RTC/DS1307RTC.h:20:23: error: 'tmElements_t' has not been declared static bool write(tmElements_t &tm); ^ sketch_oct01a.ino:13:1: error: 'tmElements_t' does not name a type sketch_oct01a.ino: In function 'void setup()': sketch_oct01a.ino:23:21: error: expected primary-expression before ')' token sketch_oct01a.ino: In function 'bool getTime(const char*)': sketch_oct01a.ino:56:5: error: expected unqualified-id before '.' token sketch_oct01a.ino:57:5: error: expected unqualified-id before '.' token sketch_oct01a.ino:58:5: error: expected unqualified-id before '.' token sketch_oct01a.ino: In function 'bool getDate(const char*)': sketch_oct01a.ino:73:5: error: expected unqualified-id before '.' token sketch_oct01a.ino:74:5: error: expected unqualified-id before '.' token sketch_oct01a.ino:75:5: error: expected unqualified-id before '.' token
This report would have more information with "Show verbose output during compilation" enabled in File > Preferences.
it show error like this
Maybe you don't have that library installed?
will u pls provide me the link of that libary thanks
salaideva: will u pls provide me the link of that libary thanks
I think it was this one, which I found in the Playground:
http://www.pjrc.com/teensy/td_libs_DS1307RTC.html
In any case, you might find the playground useful:
http://playground.arduino.cc/code/time
IIRC the 1307 is a 5v-only chip, will it work with 3v3 signals?
Rob
JimboZA: In any case, you might find the playground useful:
The Time library is not compatible with the Due. I haven't tried PJRC's improved version but am fairly certain that it would not be, either. Have a look at these:
http://forum.arduino.cc/index.php/topic,136843.0.html http://forum.arduino.cc/index.php/topic,136126.0.html https://github.com/MarkusLange/Arduino-Due-RTC-Library
Graynomad: IIRC the 1307 is a 5v-only chip, will it work with 3v3 signals?
You do recall correctly, recommended supply voltage is 4.5V min, 5.0V typical, 5.5V max.
