Regarding the Programming of IR obstacle sensor
I am trying to build a anemometer using IR sensor. I designed it as the number of rotation is calculated using the number of times obstacle appeared in IR sensor. Can any one share the code ?
You may need to add a few lines of code to implement your undefined requirements.
PaulS:
That's like the instructions for doing diy sculptures: Take a big lump of rock, and chip off the bits you don't need :wink:
