Regarding Type Conversion
float i; i = 1 + (float) 5 / (int) 2.0 ;
Considering the code above, the output of value i is 3.5. Now, I was wondering during the evaluation of division why float was given precedence. I mean why the result of division was 2.5 instead of 2?
because that's the rule. Look up C++ coercion rule.
hyperrobotix: float i; i = 1 + (float) 5 / (int) 2.0 ;
when you mix data types, the compiler "promotes" all the lesser ones to the level of the "greatest" one.
For example:
[b]uint16_t var1 = 5;
uint32_t var2 = 10;
float var3 = 1.5;
[/b]
[b]Serial.print (var1 * var2 * var3);[/b]
will result in 75.0 (a float value);
var1 and var2 both get "promoted" to the type "float" so that when the calculation is done, it's actually doing this:
[b]Serial.print (float * float * float);[/b]
The math calculation order of operations is irrelevant.
Hope this helps.
