Regarding u after number
Hello. I was testing adding u after int number in Arduino enviroment. As u specifies that the data type is unsigned, int value in Arduino should be stored from 0 to 65535. But even though I am assigning value less than 65535, the code is outputting wrong value of -25536 :confused:
int i= 40000u;
void setup(){
Serial.println(i);
void loop(){}
40000 is not representable in a sixteen bit signed int.
Use "unsigned int" or uint16_t
You specifically defined i as a signed int. You can't then override that definition by just adding U after the initialisation value.
Steve
