Hi guys .,
I am getting a weird issue here ., lot confusing me ., I am writing (Serial.write) data of 115200 bps to HC05 Bluetooth module ., which i connected in the Serial3 of Arduino DUE board .,
data is like this
when i send {a} the Bluetooth has to send me 7 byte data ( comes only once no continuous )
when i send {c} the bluetooth has to send me 29 bytes data ( long data streaming continuous ) until i send {g} to STOP the data sending .
i download the blue tooth reading app TerminalBT from play store and sending commands ., The high bytes data i could see in my terminalBT as ASCII values ., but low byte count data i am not able to see in my terminalBT window .,
I downloaded many Bluetooth readers to verify this all the same .,
Another issue is in high speed data what i get i am not getting first byte in my buffer i am simply sending as char data ., is it i need to use CTS ,RTS with my program to sync the data sending to bluetooth socket ? .
the same data i am writing to SerialUSB native port in parallel i get all data properly with first byte is sitting in first array buffer .
Please advice if i missed out any thing here .
Sending Low byte data write
void send_data(char a)
SerialUSB.write(a);
Serial3.write(a);
Code at sending high byte data write
SerialUSB.write(temp,28);
Serial3.write(temp,28);
