register-level programming querie
Hello
I've made a similar message before but don't think my message was clear to understand. I currently have a simple code that allows my function generators signal to be displayed on my PC's screen using serial plotter.
I am trying now to replicate the same code but in register-level programming and don't know where to start or any where i can find this information. I would be greatful for any help.
[/int analogPin = A0;
int val = 0;
Serial.begin(4800)
val=analogRead(analogPin);
Serial.println(val);
delay(5);
You can see the registers involved in the functions you referenced by looking at the source of these functions.
If you have installed the IDE, you have the source.
I'm puzzled why you'd want it do this though.
Your code doesn't compile, BTW.
I have exams coming up for register-level programming so i need to understand how to do these types of programming techniques.
I'm still not sure how to look at the source, do i have to open the arduino IDE page and go into settings
fawkes_abbes:
also learn the processor:
http://www.atmel.com/images/Atmel-8271-8-bit-AVR-Microcontroller-ATmega48A-48PA-88A-88PA-168A-168PA-328-328P_datasheet_Complete.pdf
by 'register-level programming' do you mean
the machine level code
OR
you just want to know what values are are being put into the corresponding registers for your example code?
for the latter, you can simply open up the related libraries to see how it is done.
(deleted)
