Hello,
I am using a library that defines a lot of different variables manually (I think; correct me if I am wrong) -
for instance:
ad7124_st_reg ad7124_regs[57] = {
{0x00, 0x00, 1, 2}, /* AD7124_Status */
{0x01, 0x0000, 2, 1}, /* AD7124_ADC_Control */
{0x02, 0x0000, 3, 2}, /* AD7124_Data */
{0x03, 0x000000, 3, 1}, /* AD7124_IOCon1 */
{0x04, 0x0000, 2, 1}, /* AD7124_IOCon2 */
{0x05, 0x12, 1, 2}, /* AD7124_ID */
{0x06, 0x0000, 3, 2}, /* AD7124_Error */
{0x07, 0x000040, 3, 1}, /* AD7124_Error_En */
{0x08, 0x00, 1, 2}, /* AD7124_Mclk_Count */
{0x09, 0x8001, 2, 1}, /* AD7124_Channel_0 */
{0x0A, 0x0001, 2, 1}, /* AD7124_Channel_1 */
{0x0B, 0x0001, 2, 1}, /* AD7124_Channel_2 */
{0x0C, 0x0001, 2, 1}, /* AD7124_Channel_3 */
{0x0D, 0x0001, 2, 1}, /* AD7124_Channel_4 */
{0x0E, 0x0001, 2, 1}, /* AD7124_Channel_5 */
{0x0F, 0x0001, 2, 1}, /* AD7124_Channel_6 */
{0x10, 0x0001, 2, 1}, /* AD7124_Channel_7 */
{0x11, 0x0001, 2, 1}, /* AD7124_Channel_8 */
{0x12, 0x0001, 2, 1}, /* AD7124_Channel_9 */
{0x13, 0x0001, 2, 1}, /* AD7124_Channel_10 */
{0x14, 0x0001, 2, 1}, /* AD7124_Channel_11 */
{0x15, 0x0001, 2, 1}, /* AD7124_Channel_12 */
{0x16, 0x0001, 2, 1}, /* AD7124_Channel_13 */
{0x17, 0x0001, 2, 1}, /* AD7124_Channel_14 */
{0x18, 0x0001, 2, 1}, /* AD7124_Channel_15 */
{0x19, 0x0860, 2, 1}, /* AD7124_Config_0 */
{0x1A, 0x0860, 2, 1}, /* AD7124_Config_1 */
{0x1B, 0x0860, 2, 1}, /* AD7124_Config_2 */
{0x1C, 0x0860, 2, 1}, /* AD7124_Config_3 */
{0x1D, 0x0860, 2, 1}, /* AD7124_Config_4 */
{0x1E, 0x0860, 2, 1}, /* AD7124_Config_5 */
{0x1F, 0x0860, 2, 1}, /* AD7124_Config_6 */
{0x20, 0x0860, 2, 1}, /* AD7124_Config_7 */
{0x21, 0x060180, 3, 1}, /* AD7124_Filter_0 */
{0x22, 0x060180, 3, 1}, /* AD7124_Filter_1 */
{0x23, 0x060180, 3, 1}, /* AD7124_Filter_2 */
{0x24, 0x060180, 3, 1}, /* AD7124_Filter_3 */
{0x25, 0x060180, 3, 1}, /* AD7124_Filter_4 */
{0x26, 0x060180, 3, 1}, /* AD7124_Filter_5 */
{0x27, 0x060180, 3, 1}, /* AD7124_Filter_6 */
{0x28, 0x060180, 3, 1}, /* AD7124_Filter_7 */
{0x29, 0x800000, 3, 1}, /* AD7124_Offset_0 */
{0x2A, 0x800000, 3, 1}, /* AD7124_Offset_1 */
{0x2B, 0x800000, 3, 1}, /* AD7124_Offset_2 */
{0x2C, 0x800000, 3, 1}, /* AD7124_Offset_3 */
{0x2D, 0x800000, 3, 1}, /* AD7124_Offset_4 */
{0x2E, 0x800000, 3, 1}, /* AD7124_Offset_5 */
{0x2F, 0x800000, 3, 1}, /* AD7124_Offset_6 */
{0x30, 0x800000, 3, 1}, /* AD7124_Offset_7 */
{0x31, 0x500000, 3, 1}, /* AD7124_Gain_0 */
{0x32, 0x500000, 3, 1}, /* AD7124_Gain_1 */
{0x33, 0x500000, 3, 1}, /* AD7124_Gain_2 */
{0x34, 0x500000, 3, 1}, /* AD7124_Gain_3 */
{0x35, 0x500000, 3, 1}, /* AD7124_Gain_4 */
{0x36, 0x500000, 3, 1}, /* AD7124_Gain_5 */
{0x37, 0x500000, 3, 1}, /* AD7124_Gain_6 */
{0x38, 0x500000, 3, 1}, /* AD7124_Gain_7 */
Now my next question is:
If I make a sketch and include the library mentioned above,
When I then declare a variable (example uint32_t myVars[5]; ), does the Arduino automatically make sure that my variable occupies a "free" register(s) space so that no conflict occurs?
I am wondering about this because there is some problem with my code and I am troubleshooting...
Best regards - Einar.
