Hi Community.
My group is trying use an arduino to check whenever a voltage output from a reflection print is 5 V or 0 V. We use Atmel Studio 6 for programming the arduino.
Best regards, students from scandinavia
Hi Community.
Hello
And the question is?
And your code is?
J-M-L:
HelloAnd the question is?
And your code is?
And your circuit is?
Don't forget to tie your -/PE/GND together...
I have a reflectionprint, givin an output of 0V when a fotodiode recieves no reflection from a reflex, and an output og 5 V when the fotodiode does. I want my arduino (mega 2560) to be able to register this change in output from the reflectionprint.
Have a look at the state-change-detection example that comes with the IDE.
What is a "reflectionprint", which photodiode / module are you using exactly?
How noisy is the signal?
Photodiodes are analog not digital, which usually means using analogRead()
