Regulating 20vac to 5vdc
Hi All,
Would somebody please advise the ideal/ correct way to regulate a 20vac to 5vdc. i'vemmm just started the assembling part and that is when i noticed that the L7805CV IC gets a little between 70and 75c.
would a heat sink help here ?
anishkgt:
Yes, but...
and how big depends on the current that you expect to draw from the 5V; more current, more heat to draw out.
What(and Watt...pun intended) are you trying to power?
this would be just a standalone arduino only.
it is never a good idea to apply a unrectified AC voltage to a DC regulator. A 20V AC Will rectify to approximately 25V. You're putting it into an analog regulator. The higher the voltage, the higher the wattage dissipation, And the hotter the regulator. you should be using a regulated DC power supply. The recommended power is 9V at 1A. But you can use up to 16V. But the regulator will be hotter than normal. you also may have a second problem. The unrectified AC current will be intermittent. If the current is not rectified with the proper capacitor, you may be introducing a line frequency into your Arduino. This could upset the Arduino's clock cycle and cause erratic behavior.
your Arduino is designed to use a 9V 1A DC regulated power supply. using an AC power supply, or even a unregulated transformer type power supply can cause problems.
Well yea I did expect heat loss. I could not get the 9v 1A of the same spec Alan's this was the closest to it on mouser more these took 2 months to get it delivered. I already bought a couple of these so I will not able to return them.
What would be the.l best way overcome this ? Add another regulator to bring the voltage down like the 7809v
That would help spread the heat into two devices. However best would be a switching otherwise known as Buck regulator.
adding a buck converter would just increase the cost as well more components and am out of space on the PCB. I was thinking of a heat sink or 7809 or maybe both.
20vac to 5vdc with just one regulator? Doesn't get dirtier than that. I strongly advice to make a proper system that first transforms the voltage down (tranformer), rectifies it (FULL BRIDGE RECTIFIER), smoothens it (capacitor) and finally regulates it. Or build a buck converter. Invest in these parts or find a proper wall adapter that has a dc output and feed that into the rectifier.
The schematic attached earlier and the one now does have a transformer, full bridge rectifier tow caps at the input and at the out of the regulator. i don't plan to change the transformer, that i cannot get a replacement to the same model. Till then am trying all other possibilities.
If you stick to this design the only thing you can do is or get a heatsink or get a better transformer for your application.
Do you have space for 4x 1N4007 diodes, or similar, to build a bridge rectifier? And perhaps a smoothing cap?
Doesn't the schematic already have all those.
anishkgt:
Yes, it's been there from the beginning, but a few have dispensed "advice" without having looked at it (not an uncommon occurrence here).
Why would you not try placing a heatsink on your own, without asking about it? If you have a chunk of metal, bolt it to the thing and get on with it.
anishkgt:
I agree about the cost, but a component like this http://it.farnell.com/recom-power/r-78e5-0-0-5/convertitore-da-dc-a-dc-5v-2-5w/dp/2078564 does not increase so much the space on pcb, and easy solve the problem.
Ciao, Ale.
Thanks ! looks like a good component to replace the traditional L7805. I've already purchased a lot of 7805 for the project. Will add this in my future design.
If your current needs are modest, get a power resistor to suck up some of the excess power. If you only need 50 mA, a 200 ohm, 1 W might do nicely.
That is the buck converter that I suggested and you rejected a few posts back.
Also your power LED is backwards on the schematic.
ilguargua:
Ciao, Ale.
Unfortunately that's rated with an abs max input voltage of 28V so it will blow up with 30 ish volts on the
input.
20vac rectified is about 28V, but an unloaded transformer puts out 10% more than its rated voltage,
so 22V rectifies to about 30V, and then any spikes on the mains will add to that - the regulator you
need must be rated for 40V or so.
I'd suggest regulating to 15V with an 7815 on a heatsink, then use the buck converter to drop to 5V.
Grumpy_Mike:
Oh when you said buck converters i was thinking of those cheap chinese ones on ebay like these. Sorry about that.
Backwards in the sense ? on the input ? that was intentionally done.
