regulation
Good day, im having a problem with a program (my com port is picking wrong values)…
here’s the code
#include <math.h>
#include <Servo.h>
//Constants
#define BAUD0 9600        //USB FTDI baud rate
#define ECHOPIN0 5        //Echo pin 0
#define ECHOPIN1 6        //Echo pin 1
#define MINPULSE 600     //Minimum servo pulse
#define MAXPULSE 2400   //Maximum servo pulse
#define TRIGPIN0 7         //Trig pin 0
#define TRIGPIN1 8         //Trig pin 1
Servo servo0;           //Creating servo object servo0
Servo servo1;           //Creating servo object servo1
//Variables
bool sdelay = false;
int delaytime = 50;
int cm0, precm0=1;
int cm1, precm1=1;
int val0, val1, maxdeg;
long duration0;
long duration1;
//PING DDC
long microsecondsToCentimeters(long microseconds)
  return microseconds / 29 / 2;
//DEBUGG
void debugg()
  Serial.print(val0);
  Serial.print(" ");
  Serial.print(val1);
//SETUP
  Serial.begin(BAUD0);
  pinMode(TRIGPIN0, OUTPUT);
  pinMode(ECHOPIN0, INPUT);
  pinMode(TRIGPIN1, OUTPUT);
  pinMode(ECHOPIN1, INPUT);
  servo0.attach(9, MINPULSE, MAXPULSE);
  servo1.attach(10, MINPULSE, MAXPULSE);
//MAIN
  //Ping sensor 0 reading
  digitalWrite(TRIGPIN0, LOW);
  delay(2);
  digitalWrite(TRIGPIN0, HIGH);
  delay(5);
  duration0 = pulseIn(ECHOPIN0, HIGH);
  cm0 = microsecondsToCentimeters(duration0);
  cm0 = map(cm0, 5, 20, 5, 20);
  //Ping sensor 1 reading
  digitalWrite(TRIGPIN1, LOW);
  delay(2);
  digitalWrite(TRIGPIN1, HIGH);
  delay(5);
  duration1 = pulseIn(ECHOPIN1, HIGH);
  cm1 = microsecondsToCentimeters(duration1);
  cm1 = map(cm1, 5, 20, 5, 20);
  //Mapping the readings to the corresponding servo angles
  maxdeg = map(cm0, 20, 5, 0, 90);
  val0 = map(cm1, 5, 20, maxdeg, 0);
  val1 = map(cm1, 5, 20, 0, maxdeg);
  switch(cm0)
    case 20:
      if(20-precm0>=5)    //Hand removed quickly from the ultrasonic sensor (moved from the line of sensor reading)
        servo0.write(val0);
        sdelay=true;
    default:    //Default action (hand moved on the "line of sensor reading")
      servo0.write(val0);
      sdelay=true;
      precm0=cm0;
  switch(cm1)
    case 20:
      if(20-precm1>=5)
        servo1.write(val1);
        sdelay=true;
    default:
      servo1.write(val1);
      sdelay=true;
      precm1=cm1;
  //Writing the values to the servos, applying the delays (if needed), and monitoring the results via UART
  servo0.write(val0);
  servo1.write(val1);
  if(sdelay==true) delay(delaytime);
  sdelay=false;
  debugg();
I think the way of mine thinking is pretty clear, but if any doubts i can further explain…
thanks :slight_smile:
xvjeko: I think the way of mine thinking is pretty clear, but if any doubts i can further explain...
It's not. "Picking the wrong values" doesn't really tell me your issue.
What is your sketch designed to do?
What values is the com port "picking"?
What values are you expecting and why?
Arrch:
sketch is designed to pick values from 2 ultrasonic sensors, and depending on the values picked, operate 2 servo motors (motors need to recieve angles from 0 to 90, and im picking values from -400 to 800)
What do you think this is doing?
A switch statement with 2 cases would be better as an if/else.
It does not "pick" values from ping sensors, like it had a choice. It reads values from ping sensors, getting whatever the sensor detects.
Why are you picking values from -400 to 800 if the servo needs a value in the range 0 to 90?
Where are your debug statements? Where is your debug output?
And, no, I don't want to see a long list of nameless values. Prefix the value with the name of the variable, so we have some idea what is being read/computed/mapped/etc.
