Reinstall bootloader from nothing
So, I have a slight problem.
This was caused by a stray 12V wire coming into contact with a pin on my breadboard frying a couple components and screwing up the Arduino. The chip is a DIP 328P-PU
I am trying to reinstall via avrdude, with no success.
The verbose output is as follows:
 avrdude -c dapa -P /dev/parport0 -p atmega328p -F -e -v -U flash:w:optiboot_atmega328.hex
avrdude: Version 6.2
         Copyright (c) 2007-2014 Joerg Wunsch
         System wide configuration file is "/etc/avrdude.conf"
         User configuration file is "/home/matthew/.avrduderc"
         User configuration file does not exist or is not a regular file, skipping
         Using Port                    : /dev/parport0
         Using Programmer              : dapa
         AVR Part                      : ATmega328P
         Chip Erase delay              : 9000 us
         PAGEL                         : PD7
         BS2                           : PC2
         RESET disposition             : dedicated
         RETRY pulse                   : SCK
         serial program mode           : yes
         parallel program mode         : yes
         Timeout                       : 200
         StabDelay                     : 100
         CmdexeDelay                   : 25
         SyncLoops                     : 32
         ByteDelay                     : 0
         PollIndex                     : 3
         PollValue                     : 0x53
         Memory Detail                 :
                                  Block Poll               Page                       Polled
           Memory Type Mode Delay Size  Indx Paged  Size   Size #Pages MinW  MaxW   ReadBack
           eeprom        65    20     4    0 no       1024    4      0  3600  3600 0xff 0xff
           flash         65     6   128    0 yes     32768  128    256  4500  4500 0xff 0xff
           lfuse          0     0     0    0 no          1    0      0  4500  4500 0x00 0x00
           hfuse          0     0     0    0 no          1    0      0  4500  4500 0x00 0x00
           efuse          0     0     0    0 no          1    0      0  4500  4500 0x00 0x00
           lock           0     0     0    0 no          1    0      0  4500  4500 0x00 0x00
           calibration    0     0     0    0 no          1    0      0     0     0 0x00 0x00
           signature      0     0     0    0 no          3    0      0     0     0 0x00 0x00
         Programmer Type : PPI
         Description     : Direct AVR Parallel Access cable
           VCC     =  3
           BUFF    =  (not used)
           RESET   =  16
           SCK     =  1
           MOSI    =  2
           MISO    =  11
           ERR LED =  (not used)
           RDY LED =  (not used)
           PGM LED =  (not used)
           VFY LED =  (not used)
avrdude: AVR device initialized and ready to accept instructions
Reading | ################################################## | 100% 0.00s
avrdude: Device signature = 0x000102
avrdude: Expected signature for ATmega328P is 1E 95 0F
avrdude: safemode: hfuse reads as 0
avrdude: safemode: efuse reads as 0
avrdude: erasing chip
avrdude: reading input file "optiboot_atmega328.hex"
avrdude: input file optiboot_atmega328.hex auto detected as Intel Hex
avrdude: writing flash (32768 bytes):
Writing | ################################################## | 100% 0.20s
avrdude: 32768 bytes of flash written
avrdude: verifying flash memory against optiboot_atmega328.hex:
avrdude: load data flash data from input file optiboot_atmega328.hex:
avrdude: input file optiboot_atmega328.hex contains 32768 bytes
avrdude: reading on-chip flash data:
Reading | ################################################## | 100% 0.18s
avrdude: verifying ...
avrdude: verification error, first mismatch at byte 0x7e00
         0x00 != 0x11
avrdude: verification error; content mismatch
avrdude: safemode: Fuses OK (E:00, H:00, L:00)
avrdude done.  Thank you.
I tried using arduino as ISP and it too failed, so I went to avrdude via bit-bang parallel port. The cable works, not exactly correct due to the resistors I had on hand, but what works, works. It clearly gets a reply so its all good. I just don't know what to do anymore.
Is the DIP warm or hot to the touch? Replace the 328P.
Sparkfun or Adafruit if you want one that is bootloaded already. Get a spare too.
Or start using Promini + FTDI Basic in your project, more modular in case you blow something.
Bear in mind there is a good chance you’ve destroyed the 328 chip .
I use a cheap programmer connected to the ICSP port for uploading bootloaders, simple to use and works well
Chip may be damaged.
000102 sig often indicates problem with the reset line (particularly the reset line being stuck low for some reason - potentially damage to the chip. But the reset pin is the one pin on the chip that shouldn't be harmed by 12V...)
