hai.. may i know. it is possible to control for the coin acceptor to reject a coin by using arduino. i try to search related topic about it but couldn't find. The specification said it can be control using a controller.
What coin acceptor?
You need to post a link to the datasheet.
....R
data sheets shows output for the make and model.
if yours is different, then the output will be different.
im using jy-923 coin acceptor.. i try to find the datasheet but could'nt find.. right now im able to receive the coin, and display it at lcd, but i dont know how to make the coin to reject in a certain amount
M_shahir:
Without the datasheet, how can you expect us to help?
...R
Note #5 under Features tells you how to set the accuracy. It says "1" is the most accurate (so there may a chance of rejecting a good coin) and "30" is the least accurate (so more likely to accept a bad/fake coin).
The datasheet looks a little "light" to me... It doesn't tell you what kind of data you're getting from it... There is a standard (or maybe more than one standard) for coin mechanisms. I found: [u]Multi-drop Bus[/u] and maybe that's what it uses.
There's also something about "AP" mode in the datasheet, so you might do some research to find out what that is...
alright.. tq for your help.. i will leave a comment after i make it..
