Relative pressure sensor wall connectors
Hello,
I am looking for this blue wall connector that connects a relative pressure sensor inside a housing with external tubes. Right now I am trying to find this component but I am completely unable to find it anywhere. Does anyone know where I can find it?
Thank you!
Can we have that again, but this time with detail?
The pressure sensor used is the following in the image and the plastic tubes are all 3mm. I hope this is enough information.
Search for a 3mm bulkhead fitting.
Don't know if you will find the exact fitting, but if you are just wanting to run a 3mm hose through a panel any 3mm bulkhead should work
Thank you very much!
