Relay 5V Always Contact when Use External Power Supply
Hi, I have project to make Modbus Relay. I use Arduino Uno, TTL to RS485 (max485) module, and relay 1 CH. When programming and I upload the program to Arduino Uno, the relay work normal with no issue (use power from USB). But when I Use buck converter LM2596S Module for buck from 24 V to 5V, the relay always contact (not using power from USB). This relay use LOW trigger to contact. Here the program and the wiring diagram
#include <SoftwareSerial.h>
#include <ModbusRTUSlave.h>
const uint8_t rxPin = 10; //for RO
const uint8_t txPin = 11; //for DI
const uint8_t dePin = 13; //for DE_RE
SoftwareSerial ModbusSer(rxPin, txPin);
ModbusRTUSlave ModbusSlave(ModbusSer, dePin); // serial port, driver enable pin for rs-485 (optional)
bool coils[8] = {0, 0, 0, 0, 0, 0, 0, 0}; // Initiation Coil Status
const int pinD4 = 4; //For Trigger Relay
  pinMode(pinD4, OUTPUT);
  ModbusSlave.configureCoils(coils, 8);                       // bool array of coil values, number of coils
  ModbusSlave.begin(2, 38400);                                // slave id, baud rate, config (optional)
  ModbusSlave.poll();
  if (coils[0] == 1)
    digitalWrite(pinD4, LOW);
    digitalWrite(pinD4, HIGH);
Best Regards
Caraka Tri
The '2596 output should not go to VIN, but to "5V".
Wow. It's work normal. Thankyou. Why output from 2596 should go to 5V, not to Vin?
VIN is for "8V", minimum. It is basically the equivalent of the barrel jack, but the barrel jack is fuse protected.
Thankyou @anon85221860 you're very helpful' :+1:t4:
