Relay always turned on?
Hi. Since I haven’tr found any datasheet or some information regarding the Relay, I want to know if I can keep the ri1318 relay about 3 hours powered…
The label say its 10A.
I’ll use always < than 5A for about 3 hours about 4 or 5 times a day.
Have someone some experience regarding this device?
Tks
Should be OK. Are you using bare relay or relay module?
alesam:
Only Relay with BD139 as a switch and a diode 1N4004 avoind return to the transistor
I'd recommend to use this schematic to reduce power consumption by relay coil.
alesam:
Thank you.. It is almost your schema... Tks a lot...
My concern is most about if the relay can be powered for long time..(more than 3 hours)
Are you concerned about coil overheating or contacts reliability?
alesam:
Actually both
When turned on for about 3 hours, its warm... not very hot, but hot.
Warm (below 45 degree C) is OK.
alesam:
I need to check this to be sure, but I think its not that hot
