I have a 8 relay board and would like to set in up to turn the relays on at different time for different lengths of time. any help with code would be awesome or help point me in the right direction
Here is my sketch so for I am not sure how to get the times correct. I want relay 1 to turn on then 10 minutes later the other 3 to turn on and run for 12 hours.
// set pin numbers:
#define Relay1 2
#define Relay2 3
#define Relay3 4
#define Relay4 5
// Variables will change:
long previousMillis = 0;
pinMode(Relay1, OUTPUT);
digitalWrite(Relay1, HIGH);
pinMode(Relay2, OUTPUT);
digitalWrite(Relay2, HIGH);
pinMode(Relay3, OUTPUT);
digitalWrite(Relay3, HIGH);
if (currentMillis - previousMillis < 5000)
digitalWrite(Relay1, LOW);
if (currentMillis - previousMillis > 5000 && currentMillis - previousMillis < 10000)
digitalWrite(Relay2, LOW);
if (currentMillis - previousMillis > 10000 && currentMillis - previousMillis < 15000)
digitalWrite(Relay3, LOW);
digitalWrite(Relay4, LOW);
digitalWrite(Relay4, HIGH);
/code]
here's the bones of a sketch I'm working on for a 16ch relay board using arrays
byte relayNum[] = {22, 23, 24, 25, 26, 27, 28, 29, 30, 31, 32, 33, 34, 35, 36, 37 }; //relayNum[0] - [15]
byte relayCount = 16;
boolean RelayState[] = {1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1};
//boolean ON = LOW;
//boolean OFF = HIGH;
unsigned long relayOnTime[] = {250, 500, 1000, 250, 500, 1000, 250, 500, 1000, 250, 500, 1000, 250, 500, 1000, 250}; //relayOnTime[arrayPosition][0] - [15]
unsigned long relayOffTime[] = {1000, 1000, 1000, 1000, 1000, 1000, 1000, 1000, 1000, 1000, 1000, 1000, 1000, 1000, 1000, 1000}; //relayOffTime[arrayPosition][0] - [15]
unsigned long currentMillis;
unsigned long RelaypreviousMillis[] = {0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0};
//set relay pins out and high (=off)
for (byte arrayPosition = 0; arrayPosition < relayCount; arrayPosition++) {
pinMode(relayNum[arrayPosition], OUTPUT);
digitalWrite(relayNum[arrayPosition], HIGH);
testCycle();
} //setup
cycleRelays();
} //loop
void cycleRelays() {
if ((RelayState[arrayPosition] == HIGH) && (currentMillis - RelaypreviousMillis[arrayPosition] >= relayOffTime[arrayPosition]))
RelayState[arrayPosition] = LOW; // Turn it on
RelaypreviousMillis[arrayPosition] = currentMillis; // Remember the time
digitalWrite(relayNum[arrayPosition], RelayState[arrayPosition]); // Update the [arrayPosition] RelayState
else if ((RelayState[arrayPosition] == LOW) && (currentMillis - RelaypreviousMillis[arrayPosition] >= relayOnTime[arrayPosition]))
RelayState[arrayPosition] = HIGH; // turn it off
} //cycleRelays
void testCycle() {
// arrays for cycle time for test routine
int testSwitchIncrement[] = {10, 20, 30, 40, 50, 60, 70, 80, 90, 100, 110, 120, 130, 140, 150, 1000}; //test delay Time array [0] - [15]
int testSwitchDecrement[] = {1000, 150, 140, 130, 120, 110, 100, 90, 80, 70, 60, 50, 40, 30, 20, 10}; //test delay Time array [0] - [15]
// Increment:
digitalWrite(relayNum[arrayPosition], LOW); // "ON"
delay(testSwitchIncrement[arrayPosition]);
digitalWrite(relayNum[arrayPosition], HIGH); // "OFF"
// Decrement:
for (byte arrayPosition = relayCount--; arrayPosition >= 0; arrayPosition--) {
delay(testSwitchDecrement[arrayPosition]);
} //testCycle
And 1 milli = 1/1000th of a second so (((1 millis()*1000= 1 second) *60 for minutes) *60 for hours) etc.
rlawns83:
You forgot to initialize the pin for Relay4.
Relay1 is turned on for the first 5 seconds after reset, then turned off. Change that to 10 minutes (600,000 milliseconds).
Relay2 is turned on from 5 seconds to 10 seconds. Change that to come on at 10 minutes and off at 12 hours and 10 minutes. Then you can turn Relay3 and Relay4 on and off at those same times.
You have not said what happens after the 12 hours and 10 minutes. As the code is written the cycle will start again in about 49 days when the time rolls over to 0.
