Hey all, I'm trying to deal with this odd issue on an Arduino Uno -
I've got a 4 channel relay attached to digital pins 10-13. Whenever the relay is connected, the serial monitor will function correctly for a brief amount of time, then stop. Closing and attemping to re-open the window causes a "Serial port COMx already in use" error, and the REALLY weird part, is that uploading code to the board over USB fails after the serial monitor stops working.
avrdude throws up an error when the board fails to upload:
avrdude: ser_send(): write error; sorry no info avail
I've seen another error from avrdude come up as well, something about the COM port and not being able to write. I've tried reproducing the error to get the debug info, but have met little success.
The transmit LED is blinking, nothing else is reading COM port data.
Full code:
#include <Wire.h>
#include "TSL2561.h"
#include "Timer.h"
#include "DHT.h"
#define Temp1 A0
#define Temp2 A1
#define mos0 7 // Exhaust
#define mos1 8 // Power Supply
#define in1 10 // Fogger
#define in2 11 // Lights 2 & 3
#define in3 12 // Light 1
#define in4 13 // TEC big fan
float lumnP0; // Lux variable
float hmdtP0; // humidity variable
float tempP0; // temp sensor 0
float tempP1; // temp sensor 1
float tempP2; // temp sensor 2
float tmpAvg; // average temp.
#define RELAY_ON 0
#define RELAY_OFF 1
#define DHTPIN 2
#define DHTTYPE DHT22
TSL2561 tsl(TSL2561_ADDR_FLOAT);
DHT dht(DHTPIN, DHTTYPE);
Timer t;
// Set MOSFET control pins to output:
pinMode(mos0, OUTPUT);
pinMode(mos1, OUTPUT);
// Setup relays
digitalWrite(in1, RELAY_OFF);
digitalWrite(in2, RELAY_OFF);
digitalWrite(in3, RELAY_OFF);
digitalWrite(in4, RELAY_OFF);
pinMode(in1, OUTPUT);
pinMode(in2, OUTPUT);
pinMode(in3, OUTPUT);
pinMode(in4, OUTPUT);
t.pulse(in2, 43200 * 1000, RELAY_ON); // 12/12 light cycle
t.pulse(in3, 43200 * 1000, RELAY_ON); // for both light banks
t.every(1000, DataRead);
t.every(10000, EnvirCntrl);
if (tsl.begin()) {
Serial.println("Found sensor!");
Serial.println("No sensor?");
while (1);
tsl.setGain(TSL2561_GAIN_0X); // 16x for dim situations.
dht.begin();
t.update();
uint32_t lum = tsl.getFullLuminosity();
uint16_t ir, full;
ir = lum >> 16;
full = lum & 0xFFFF;
float hmdtR0 = dht.readHumidity();
float tempR0 = dht.readTemperature();
float tempR1 = analogRead(Temp1);
float tempR2 = analogRead(Temp2);
float tempC1 = (((125.0 * tempR1) / 256.0) - 50.0);
float tempC2 = (((125.0 * tempR2) / 256.0) - 50.0);
float lumnR0 = tsl.calculateLux(full, ir);
hmdtP0 = hmdtR0;
tempP0 = tempR0;
tempP1 = tempC1;
tempP2 = tempC2;
lumnP0 = lumnR0;
tmpAvg = ((tempP0 + tempP1) / 2);
void DataRead()
Serial.println("\t");
Serial.print("TEMP 0: "); Serial.println(tempP0);
Serial.print("TEMP 1: "); Serial.println(tempP1);
Serial.print("TEMP 2: "); Serial.println(tempP2);
Serial.print("AVG: "); Serial.println(tmpAvg);
Serial.print("HMDT 0: "); Serial.println(hmdtP0);
Serial.print("LUMN 0: "); Serial.println(lumnP0);
void EnvirCntrl()
if (tmpAvg > 30)
digitalWrite(mos1, HIGH);
digitalWrite(in4, RELAY_ON);
if (hmdtP0 < 60)
digitalWrite(in1, RELAY_ON);
Any clues? With this board controlling AC, I feel a bit odd about not being able to monitor anything. ![]()
