I drive 3 omron 5Vdc relays using standalone atmega328. Each relay coil consumes 42 mA as such. My assumption is something aorund (42*3) 126mA + .... But in the circuit When i drive these 3 relays using resistor and transistor it consumes only 87mA in total for 3 relays. ... Why is that? does that mean the circuit is not right.
Please help me with this ?
- the load in mA is dependent on voltage
- rated/documented values are usually worst case
- there is probably nothing wrong with your circuit
- The current it takes to initially energize a relay may not be the same as what it takes to hold it energized. IE; there may be an initial current/voltage spike that could be deadly to the ATMEGA device
Thanks.. I appreciate that..
for the 4th point.. regarding the initial large current and voltage spike is there any way i can prevent that entering the Atmega when it is powered .
It would really help if we could see your circuit! I hope you're not driving the relays directly from port pins as 42mA is too much and can damage the ATmega328.
You are right.. Actually I am not giving the arduino output directly to relay.. I use resistor and transistor inbetween. it works just fine...
You are using transistors. That should be enough to keep the Atmega isolated unless you take into account what the relay does to your power source. A weak power source may cause your Atmega to reset when the coils energize... and not protecting the circuit from the spike created when the coil de-energizes can create unwanted spikes interfering with the rest of the circuit. Hopefully you followed a transistor/relay sample circuit that uses a de-spiking/clamping diode across the coil.
