I am trying to switch On a relayfor 2 minutes from the program start and after 1 minute switch Off and again On for 2 minutes so on.. I am doing this with MCP3551 library "https://github.com/Seimen/CtrlHV/tree/master/MCP3551". But when I try to add any timer libray, the ralay is not working(I think there is a clash between these two library timings). But metro library working fine if I am not adding the MCP3551 library. So i planned to write my own code based on BlinkWithoutDelay example. But it didn't work. Can anybody point out what I am doing wrong or any alternate solution. Please find my code below..
const int ledPin = 13; // the number of the LED pin
int ledState = LOW; // ledState used to set the LED
long previousMillis = 0;
unsigned long A = 2000; // interval at which to blink (milliseconds)
unsigned long B = 1000;
unsigned long C;
unsigned long Time2;
unsigned long Time3;
pinMode(ledPin, OUTPUT);
C=A+B;
if(currentMillis <= A) {
digitalWrite(13, HIGH);
Serial.print("A)");
Serial.print(A);
Serial.print("----");
else if (currentMillis <=C)
digitalWrite(13, LOW);
else if (currentMillis > C)
A=C+A;
Serial.print("A2)");
Serial.print(A);
//delay(1000);
Dear Paul,
Thank you very much for the quick response. Please find below the changed code. That's the best name I can come up with(English is not my mother language, sorry). Now it blinked two threetimes and styed high for long time and blinked..
const int relayPin = 13; // the number of the LED pin
unsigned long on_time = 2000;
unsigned long off_time = 1000;
unsigned long sum_onoff_time;
pinMode(relayPin, OUTPUT);
sum_onoff_time=on_time + off_time;
if(currentMillis <= on_time) {
digitalWrite(relayPin, HIGH);
Serial.print("Initial on Time-");
Serial.print(on_time);
Serial.print("--");
else if (currentMillis <=sum_onoff_time)
digitalWrite(relayPin, LOW);
else if (currentMillis > sum_onoff_time)
on_time=sum_onoff_time+on_time;
Serial.print("Second On Time)");
//delay(1000);
mills returns (ignoring rollover) the number of mills since your program started. So the above code will be true only once. Take another look at blink without delay.
holmes4:
Mark
That was my first thought, too. But, on_time is modified later in the sketch.
This is because I wanted to save that values in EEPROM and increment and decrement that values using buttons(I wanted to adjust the relay ON/OFF time using UP/DOWN buttons). So this has to be in the loop. I am away from my UNO now. After 30 minutes, I will update serial output in next post, so you great people will get more clear picture as well as my complete code
