Guys,
'1284 , IDE 1.0, maniacbug environment for pin definitions, optiboot hexfile bootloader.
What am I doing wrong here?
I power, LED on D0 flashes 4 times.
What I am I doing wrong here? IDE 1.0
I enter 00, I get back
"0207207
Invalid Relay Number 207"
according to asciitable.com, character '0' is 0x30, so why is the math not working?
arrg, software ...
Relay Control Sketch
Robert Patterson, Cross Roads Fencing Center
for Brad Rojas, brojas@accllcpos.com
byte relayArray[21] = { 1, 14, 16, 18,20,22,28,1,1,1,1,1,15,17,19,21,23,24,25,26,27};
byte relayArray[0] = 1; // not used
byte relayArray[1] = 14; // T3-C10
byte relayArray[2] = 16; // T2-C2
byte relayArray[3] = 18; // T4-C2
byte relayArray[4] = 20; // T2-C3
byte relayArray[5] = 22; // T1-C5
byte relayArray[6] = 28; // T2-C5
byte relayArray[7] = 1; // not used
byte relayArray[8] = 1; // not used
byte relayArray[9] = 1; // not used
byte relayArray[10] = 1; // not used
byte relayArray[11] = 1; // not used
byte relayArray[12] = 15; // T1-C2
byte relayArray[13] = 17; // T3-C2
byte relayArray[14] = 19; // T0-C3
byte relayArray[15] = 21; // T1-C3
byte relayArray[16] = 23; // T3-C3
byte relayArray[17] = 24; // T3-C5
byte relayArray[18] = 25; // T4-C5
byte relayArray[19] = 26; // NO CONNECTIONS
byte relayArray[20] = 27; // NO CONNECTIONS
byte activityLED = 0; //
// VARIABLES
byte x = 0;
byte digitTens = 0;
byte digitOnes = 0;
byte relayNumber = 0;
byte relayValid = 0;
void setup(){
// set up relay control pins and make sure turned off
// output pins float at turn on
for (x = 1; x<21; x=x+1){
pinMode (relayArray[x], OUTPUT);
digitalWrite(relayArray[x], HIGH); // HIGH = off, LOW = energized
// Enable serial ports & clear incoming buffer
Serial.begin(9600); // USB port
Serial.flush();
//Serial1.begin(9600); // RS232 port
//Serial1.flush();
// set up activity LED, flash to show set up is done
pinMode (activityLED, OUTPUT); // HIGH = On, LOW = Off
for (int x = 0; x<4; x=x+1){ // flash a couple times on startup
digitalWrite (activityLED, HIGH);
delay (200);
digitalWrite (activityLED, LOW);
delay (200);
void loop(){
// get 2 characters from the UBS Serial port
if (Serial.available()){
digitTens = Serial.read(); // read a byte & convert from ASCII
Serial.print(digitTens, HEX);
if (Serial.available() ){
digitOnes = Serial.read();
Serial.print(digitOnes, HEX);
relayNumber = digitTens * 10 + digitOnes;
Serial.println (relayNumber);
// check of a good number
if (( relayNumber >=1 & relayNumber <=6) | (relayNumber >=12 & relayNumber <=20)){
relayValid = 1;
Serial.print("Relay Number ");
Serial.println(relayNumber);
} // end valid relay received
else {
relayValid = 0;
Serial.print ("Invalid Relay Number ");
// turn any that were on, off.
} // end turn off relays with invalid relayNumber received
// end invalid relay received
} // end if Serial available
// clear for next command
digitTens = 0;
digitOnes = 0;
// Change state of the Relay
if (relayValid == 1){
if (activityLED ==1){
digitalWrite (relayArray[relayNumber], LOW);
activityLED = 0;
// do something with the other serial port
Serial.print(relayNumber);
Serial.println ("relay on");
else {
activityLED = 1;
Serial.println ("relay off");
delay (500);
} // end change relay state
} // end void loop
