I have successfully achieved communication between two arduino uno's with the NRF24l01 modules.
I can send a value of either 1 or 0, 1 should turn a relay on and 0 turn it off on pin 8.
when I read the serial data being received I get the result that I expect, but it doesn't activate or deactivate the relay! not really sure what I am doing wrong.
Please can you take a look at the code for the receiving arduino and give me some pointers.
Many thanks
John
This Program will recieve data from the NRF24l01, depending on the result the relay on pin 8 will activate or deactivate. 1 on 0 off.
#include <SPI.h>
#include <nRF24L01.h>
#include <RF24.h>
/*-----( Declare Constants and Pin Numbers )-----*/
#define CE_PIN 9
#define CSN_PIN 10
const uint64_t pipe = 0xE8E8F0F0E1LL; // Define the transmit pipe
/*-----( Declare objects )-----*/
RF24 radio(CE_PIN, CSN_PIN); // Create a Radio
/*-----( Declare Variables )-----*/
int state; // holds relay state
int relay = 8; // declare pin 8 as relay
Serial.println("Nrf24L01 Receiver Starting");
radio.begin();
radio.openReadingPipe(1,pipe);
radio.startListening();
//--(end setup )---
if ( radio.available() )
// Read the data payload until we've received everything
bool done = false;
while (!done)
// Fetch the data
done = radio.read( &state, sizeof(unsigned long) );
Serial.println(state); // print the received data 0 or 1
digitalWrite(relay,state);// set relay as state: 1 on, 0 off
#include <SPI.h>
#include <RF24.h>
#define CE_PIN 9
#define CSN_PIN 10
radio.begin();
pinMode(relay, OUTPUT);
//--(end setup )---
bool done = false;
while (!done)
// Fetch the data
if (state = 1)
digitalWrite(relay,HIGH);// set relay as HIGH: on
