jasonlloyd:
this is for esp-01 with 4 relay module.
works for me
Rui Santos
Complete project details at http://randomnerdtutorials.com
// Load Wi-Fi library
#include <ESP8266WiFi.h>
// Replace with your network credentials
const char* ssid = “Guardians of the Gateway”;
const char* password = “**********”;
// Set static IP address
IPAddress ip(192, 168, 1, 222);
IPAddress gateway(192, 168, 1, 1);
IPAddress subnet(255, 255, 255, 0);
// Set web server port number to 80
WiFiServer server(80);
// Variable to store the HTTP request
String header;
// Auxiliar variables to store the current output state
String output0State = “off”;
String output1State = “off”;
String output2State = “off”;
String output3State = “off”;
// Assign output variables to GPIO pins
const int output0 = 0;
const int output1 = 1;
const int output2 = 2;
const int output3 = 3;
// Initialize the output variables as outputs
pinMode(output0, OUTPUT);
pinMode(output1, OUTPUT);
pinMode(output2, OUTPUT);
pinMode(output3, OUTPUT);
// Set outputs to LOW
digitalWrite(output0, LOW);
digitalWrite(output1, LOW);
digitalWrite(output2, LOW);
digitalWrite(output3, LOW);
// Connect to Wi-Fi network with SSID and password
Serial.print(“Connecting to “);
Serial.println(ssid);
WiFi.config(ip, gateway, subnet);
WiFi.begin(ssid, password);
Serial.print(”.”);
// Print local IP address and start web server
Serial.println("");
Serial.println(“WiFi connected.”);
Serial.println("IP address: ");
server.begin();
void loop(){
WiFiClient client = server.available(); // Listen for incoming clients
if (client) { // If a new client connects,
Serial.println(“New Client.”); // print a message out in the serial port
String currentLine = “”; // make a String to hold incoming data from the client
while (client.connected()) { // loop while the client’s connected
if (client.available()) { // if there’s bytes to read from the client,
char c = client.read(); // read a byte, then
Serial.write(c); // print it out the serial monitor
header += c;
if (c == ‘\n’) { // if the byte is a newline character
// if the current line is blank, you got two newline characters in a row.
// that’s the end of the client HTTP request, so send a response:
if (currentLine.length() == 0) {
// HTTP headers always start with a response code (e.g. HTTP/1.1 200 OK)
// and a content-type so the client knows what’s coming, then a blank line:
client.println(“HTTP/1.1 200 OK”);
client.println(“Content-type:text/html”);
client.println(“Connection: close”);
client.println();
// turns the GPIOs on and off
if (header.indexOf(“GET /0/on”) >= 0) {
Serial.println(“GPIO 0 on”);
output0State = “on”;
} else if (header.indexOf(“GET /0/off”) >= 0) {
Serial.println(“GPIO 0 off”);
digitalWrite(output0, HIGH);
} else if (header.indexOf(“GET /1/on”) >= 0) {
Serial.println(“GPIO 1 on”);
output1State = “on”;
} else if (header.indexOf(“GET /1/off”) >= 0) {
Serial.println(“GPIO 1 off”);
digitalWrite(output1, HIGH);
} else if (header.indexOf(“GET /2/on”) >= 0) {
Serial.println(“GPIO 2 on”);
output2State = “on”;
} else if (header.indexOf(“GET /2/off”) >= 0) {
Serial.println(“GPIO 2 off”);
digitalWrite(output2, HIGH);
} else if (header.indexOf(“GET /3/on”) >= 0) {
Serial.println(“GPIO 3 on”);
output3State = “on”;
} else if (header.indexOf(“GET /3/off”) >= 0) {
Serial.println(“GPIO 3 off”);
digitalWrite(output3, HIGH);
// Display the HTML web page
client.println("");
client.println("<meta name=“viewport” content=“width=device-width, initial-scale=1”>");
client.println("<link rel=“icon” href=“data:,”>");
// CSS to style the on/off buttons
client.println(“html { font-family: Helvetica; display: inline-block; margin: 0px auto; text-align: center;}”);
client.println(".button { background-color: #00b22c; border: none; color: white; padding: 18px;");
client.println(“text-decoration: none; font-size: 45px; cursor: pointer;}”);
client.println(".button2 {background-color: #f44242;}");
client.println(“button.button {width: calc(100% - 20px);}”);
// Web Page Heading
client.println(“
ESP-01 Web Server
// Display current state, and ON/OFF buttons for GPIO 0
client.println(“
Output 1 is " + output0State + “
// If the output0State is off, it displays the ON button
if (output0State==“off”) {
client.println(”
<a href="/0/on"><button class=“button”>ON
client.println("
<a href="/0/off"><button class=“button button2”>OFF
// Display current state, and ON/OFF buttons for GPIO 1
client.println(“
Output 2 is " + output1State + “
// If the output1State is off, it displays the ON button
if (output1State==“off”) {
client.println(”
<a href="/1/on"><button class=“button”>ON
client.println("
<a href="/1/off"><button class=“button button2”>OFF
// Display current state, and ON/OFF buttons for GPIO 2
client.println(“
Output 3 is " + output2State + “
// If the output2State is off, it displays the ON button
if (output2State==“off”) {
client.println(”
<a href="/2/on"><button class=“button”>ON
client.println("
<a href="/2/off"><button class=“button button2”>OFF
// Display current state, and ON/OFF buttons for GPIO 3
client.println(“
Output 4 is " + output3State + “
// If the output3State is off, it displays the ON button
if (output3State==“off”) {
client.println(”
<a href="/3/on"><button class=“button”>ON
client.println("
<a href="/3/off"><button class=“button button2”>OFF
// Finish web page
client.println("");
// The HTTP response ends with another blank line
client.println();
// Break out of the while loop
} else { // if you got a newline, then clear currentLine
currentLine = “”;
} else if (c != ‘\r’) { // if you got anything else but a carriage return character,
currentLine += c; // add it to the end of the currentLine
// Clear the header variable
header = “”;
// Close the connection
client.stop();
Serial.println(“Client disconnected.”);
Serial.println("");
Can anyone please help to create this code in the local wifi AP?
i want to connect to my ESP8266 and directly control the relay
