Relay controlling DC 12V computer fan switching on/off randomly
Hey I am controlling 2 computer fans controlled by 2 relays to provide airflow to a garden project I have. Both fans are activated at the same time, just by 2 separate relays. My problem is the relays switching on and off an average of 5 times a minute for milliseconds each switch. I haven’t been able to find any solutions online which is why I’m coming here. Thank you.
Here is my code the bulk of it is controlling an RTC clock
#include "Wire.h"
#include "ds3231.h"
#include "rtc_ds3231.h"
#include "LiquidCrystal_I2C.h"
#include "dht.h"
dht DHT;
int in1 = 4;
int in2 = 5;
int in3 = 6;
int in4 = 7;
   LiquidCrystal_I2C lcd(0x3F, 20, 4);
#define DHT22_PIN 8
#define Moisture A0
#define BUFF_MAX 128
   uint8_t time[8];
   char recv[BUFF_MAX];
   unsigned int recv_size = 0;
   unsigned long prev, interval = 5000;
   pinMode(in1, OUTPUT);
   digitalWrite(in1, HIGH);
   pinMode(in2, OUTPUT);
   digitalWrite(in2, HIGH);
   pinMode(in3, OUTPUT);
   digitalWrite(in3, HIGH);
   pinMode(in4, OUTPUT);
   digitalWrite(in4, HIGH);
   Wire.begin();
   DS3231_init(DS3231_INTCN);
   memset(recv, 0, BUFF_MAX);
   Serial.println("GET time");
   lcd.init();                      // initialize the lcd
   lcd.backlight();
   //Serial.println("Setting time");
   //parse_cmd("T300714422122016",16);
   int chk = DHT.read22(DHT22_PIN);
   int Moisture = analogRead(A0);
        Wire.begin();
        lcd.setCursor(0,1);
        lcd.print("Moisture     =   ");
        lcd.println(Moisture);
        lcd.setCursor (0,0);
        lcd.print("Temperature  = ");
        lcd.println(DHT.temperature);
        lcd.setCursor (0,2);
        lcd.print("Humidity     = ");
        lcd.println(DHT.humidity);
    if (DHT.humidity < 50.00)
        digitalWrite(in1, LOW);
        digitalWrite(in2, LOW);
    if (Moisture < 800)
        digitalWrite(in3, LOW);
        digitalWrite(in4, LOW);
   char in;
   char buff[BUFF_MAX];
   unsigned long now = millis();
   struct ts t;
       // show time once in a while
   if ((now - prev > interval) && (Serial.available() <= 0)) {
       DS3231_get(&t); //Get time
       lcd.setCursor(12,3); //Go to second line of the LCD Screen
       lcd.print(t.hour);
       lcd.print(":");
       if(t.min<10)
         lcd.print("0");
       lcd.print(t.min);
       lcd.print(":");
       if(t.sec<10)
         lcd.print("0");
       lcd.print(t.sec);
       prev = now;
   if (Serial.available() > 0) {
       in = Serial.read();
       if ((in == 10 || in == 13) && (recv_size > 0)) {
           parse_cmd(recv, recv_size);
           recv_size = 0;
           recv[0] = 0;
       } else if (in < 48 || in > 122) {;       // ignore ~[0-9A-Za-z]
       } else if (recv_size > BUFF_MAX - 2) {   // drop lines that are too long
           // drop
           recv_size = 0;
           recv[0] = 0;
       } else if (recv_size < BUFF_MAX - 2) {
           recv[recv_size] = in;
           recv[recv_size + 1] = 0;
           recv_size += 1;
void parse_cmd(char *cmd, int cmdsize)
   uint8_t i;
   uint8_t reg_val;
   struct ts t;
   //snprintf(buff, BUFF_MAX, "cmd was '%s' %d\n", cmd, cmdsize);
   //Serial.print(buff);
   // TssmmhhWDDMMYYYY aka set time
   if (cmd[0] == 84 && cmdsize == 16) {
       //T355720619112011
       t.sec = inp2toi(cmd, 1);
       t.min = inp2toi(cmd, 3);
       t.hour = inp2toi(cmd, 5);
       t.wday = inp2toi(cmd, 7);
       t.mday = inp2toi(cmd, 8);
       t.mon = inp2toi(cmd, 10);
       t.year = inp2toi(cmd, 12) * 100 + inp2toi(cmd, 14);
       DS3231_set(t);
       Serial.println("OK");
   } else if (cmd[0] == 49 && cmdsize == 1) {  // "1" get alarm 1
       DS3231_get_a1(&buff[0], 59);
       Serial.println(buff);
   } else if (cmd[0] == 50 && cmdsize == 1) {  // "2" get alarm 1
       DS3231_get_a2(&buff[0], 59);
   } else if (cmd[0] == 51 && cmdsize == 1) {  // "3" get aging register
       Serial.print("aging reg is ");
       Serial.println(DS3231_get_aging(), DEC);
   } else if (cmd[0] == 65 && cmdsize == 9) {  // "A" set alarm 1
       DS3231_set_creg(DS3231_INTCN | DS3231_A1IE);
       //ASSMMHHDD
       for (i = 0; i < 4; i++) {
           time[i] = (cmd[2 * i + 1] - 48) * 10 + cmd[2 * i + 2] - 48; // ss, mm, hh, dd
       uint8_t flags[5] = { 0, 0, 0, 0, 0 };
       DS3231_set_a1(time[0], time[1], time[2], time[3], flags);
   } else if (cmd[0] == 66 && cmdsize == 7) {  // "B" Set Alarm 2
       DS3231_set_creg(DS3231_INTCN | DS3231_A2IE);
       //BMMHHDD
           time[i] = (cmd[2 * i + 1] - 48) * 10 + cmd[2 * i + 2] - 48; // mm, hh, dd
       uint8_t flags[5] = { 0, 0, 0, 0 };
       DS3231_set_a2(time[0], time[1], time[2], flags);
   } else if (cmd[0] == 67 && cmdsize == 1) {  // "C" - get temperature register
       Serial.print("temperature reg is ");
       Serial.println(DS3231_get_treg(), DEC);
   } else if (cmd[0] == 68 && cmdsize == 1) {  // "D" - reset status register alarm flags
       reg_val = DS3231_get_sreg();
       reg_val &= B11111100;
       DS3231_set_sreg(reg_val);
   } else if (cmd[0] == 70 && cmdsize == 1) {  // "F" - custom fct
       reg_val = DS3231_get_addr(0x5);
       Serial.print("orig ");
       Serial.print(reg_val,DEC);
       Serial.print("month is ");
       Serial.println(bcdtodec(reg_val & 0x1F),DEC);
   } else if (cmd[0] == 71 && cmdsize == 1) {  // "G" - set aging status register
       DS3231_set_aging(0);
   } else if (cmd[0] == 83 && cmdsize == 1) {  // "S" - get status register
       Serial.print("status reg is ");
       Serial.println(DS3231_get_sreg(), DEC);
       Serial.print("unknown command prefix ");
       Serial.println(cmd[0]);
       Serial.println(cmd[0], DEC);
How are these fans powered? Is the arduino resetting when the fan comes on?
I’d start by putting in some serial prints to tell you what values are being read from the sensors. You may also want some hysterisis - i.e. turn on when moisture<790 and off when it’s > 810. Still problems? Comment the rest of the code out for now.
Why do you have a wire.begin in loop?
Yes, a lack of hysteresis and a noisy sensor output would produce those symptoms.
