I am controlling 2 computer fans controlled by 2 relays to provide airflow to a garden project I have. Both fans are activated at the same time, just by 2 separate relays. My problem is the relays switching on and off an average of 5 times a minute for milliseconds each switch. I haven’t been able to find any solutions online which is why I’m coming here. Thank you.
Here is my code the bulk of it is controlling an RTC clock
#include "Wire.h"
#include "ds3231.h"
#include "rtc_ds3231.h"
#include "LiquidCrystal_I2C.h"
#include "dht.h"
dht DHT;
int in1 = 4;
int in2 = 5;
int in3 = 6;
int in4 = 7;
LiquidCrystal_I2C lcd(0x3F, 20, 4);
#define DHT22_PIN 8
#define Moisture A0
#define BUFF_MAX 128
uint8_t time[8];
char recv[BUFF_MAX];
unsigned int recv_size = 0;
unsigned long prev, interval = 5000;
pinMode(in1, OUTPUT);
digitalWrite(in1, HIGH);
pinMode(in2, OUTPUT);
digitalWrite(in2, HIGH);
pinMode(in3, OUTPUT);
digitalWrite(in3, HIGH);
pinMode(in4, OUTPUT);
digitalWrite(in4, HIGH);
Wire.begin();
DS3231_init(DS3231_INTCN);
memset(recv, 0, BUFF_MAX);
Serial.println("GET time");
lcd.init(); // initialize the lcd
lcd.backlight();
//Serial.println("Setting time");
//parse_cmd("T300714422122016",16);
int chk = DHT.read22(DHT22_PIN);
int Moisture = analogRead(A0);
Wire.begin();
lcd.setCursor(0,1);
lcd.print("Moisture = ");
lcd.println(Moisture);
lcd.setCursor (0,0);
lcd.print("Temperature = ");
lcd.println(DHT.temperature);
lcd.setCursor (0,2);
lcd.print("Humidity = ");
lcd.println(DHT.humidity);
if (DHT.humidity < 50.00)
digitalWrite(in1, LOW);
digitalWrite(in2, LOW);
if (Moisture < 800)
digitalWrite(in3, LOW);
digitalWrite(in4, LOW);
char in;
char buff[BUFF_MAX];
unsigned long now = millis();
struct ts t;
// show time once in a while
if ((now - prev > interval) && (Serial.available() <= 0)) {
DS3231_get(&t); //Get time
lcd.setCursor(12,3); //Go to second line of the LCD Screen
lcd.print(t.hour);
lcd.print(":");
if(t.min<10)
lcd.print("0");
lcd.print(t.min);
lcd.print(":");
if(t.sec<10)
lcd.print("0");
lcd.print(t.sec);
prev = now;
if (Serial.available() > 0) {
in = Serial.read();
if ((in == 10 || in == 13) && (recv_size > 0)) {
parse_cmd(recv, recv_size);
recv_size = 0;
recv[0] = 0;
} else if (in < 48 || in > 122) {; // ignore ~[0-9A-Za-z]
} else if (recv_size > BUFF_MAX - 2) { // drop lines that are too long
// drop
recv_size = 0;
recv[0] = 0;
} else if (recv_size < BUFF_MAX - 2) {
recv[recv_size] = in;
recv[recv_size + 1] = 0;
recv_size += 1;
void parse_cmd(char *cmd, int cmdsize)
uint8_t i;
uint8_t reg_val;
struct ts t;
//snprintf(buff, BUFF_MAX, "cmd was '%s' %d\n", cmd, cmdsize);
//Serial.print(buff);
// TssmmhhWDDMMYYYY aka set time
if (cmd[0] == 84 && cmdsize == 16) {
//T355720619112011
t.sec = inp2toi(cmd, 1);
t.min = inp2toi(cmd, 3);
t.hour = inp2toi(cmd, 5);
t.wday = inp2toi(cmd, 7);
t.mday = inp2toi(cmd, 8);
t.mon = inp2toi(cmd, 10);
t.year = inp2toi(cmd, 12) * 100 + inp2toi(cmd, 14);
DS3231_set(t);
Serial.println("OK");
} else if (cmd[0] == 49 && cmdsize == 1) { // "1" get alarm 1
DS3231_get_a1(&buff[0], 59);
Serial.println(buff);
} else if (cmd[0] == 50 && cmdsize == 1) { // "2" get alarm 1
DS3231_get_a2(&buff[0], 59);
} else if (cmd[0] == 51 && cmdsize == 1) { // "3" get aging register
Serial.print("aging reg is ");
Serial.println(DS3231_get_aging(), DEC);
} else if (cmd[0] == 65 && cmdsize == 9) { // "A" set alarm 1
DS3231_set_creg(DS3231_INTCN | DS3231_A1IE);
//ASSMMHHDD
for (i = 0; i < 4; i++) {
time = (cmd[2 * i + 1] - 48) * 10 + cmd[2 * i + 2] - 48; // ss, mm, hh, dd
uint8_t flags[5] = { 0, 0, 0, 0, 0 };
DS3231_set_a1(time[0], time[1], time[2], time[3], flags);
} else if (cmd[0] == 66 && cmdsize == 7) { // "B" Set Alarm 2
DS3231_set_creg(DS3231_INTCN | DS3231_A2IE);
//BMMHHDD
time = (cmd[2 * i + 1] - 48) * 10 + cmd[2 * i + 2] - 48; // mm, hh, dd
uint8_t flags[5] = { 0, 0, 0, 0 };
DS3231_set_a2(time[0], time[1], time[2], flags);
} else if (cmd[0] == 67 && cmdsize == 1) { // "C" - get temperature register
Serial.print("temperature reg is ");
Serial.println(DS3231_get_treg(), DEC);
} else if (cmd[0] == 68 && cmdsize == 1) { // "D" - reset status register alarm flags
reg_val = DS3231_get_sreg();
reg_val &= B11111100;
DS3231_set_sreg(reg_val);
} else if (cmd[0] == 70 && cmdsize == 1) { // "F" - custom fct
reg_val = DS3231_get_addr(0x5);
Serial.print("orig ");
Serial.print(reg_val,DEC);
Serial.print("month is ");
Serial.println(bcdtodec(reg_val & 0x1F),DEC);
} else if (cmd[0] == 71 && cmdsize == 1) { // "G" - set aging status register
DS3231_set_aging(0);
} else if (cmd[0] == 83 && cmdsize == 1) { // "S" - get status register
Serial.print("status reg is ");
Serial.println(DS3231_get_sreg(), DEC);
Serial.print("unknown command prefix ");
Serial.println(cmd[0]);
Serial.println(cmd[0], DEC);
