Why does not the relay switch off?
When I pull IN plug on the breadboard, the relay goes off. But why does not it work with Digital Write LOW? The relay is powered by 5V
So I wired it: https://i.stack.imgur.com/1tA37.jpg
Arduino Code:
int relayInput = 2; // the input to the relay pin
pinMode(relayInput, OUTPUT); // initialize pin as OUTPUT
digitalWrite(relayInput, HIGH); // turn relay on
digitalWrite(relayInput, LOW); // turn relay off
Thanks for help
~Marlon
system
January 31, 2019, 3:19pm
2
So I wired it
Can YOU tell anything by that picture? I sure can't.
I only want to control the relay
system
January 31, 2019, 3:49pm
4
mar_robHD:
Then wire it properly. If you think you did, post a photo that CLEARLY shows what wire goes where, not a rats nest of wires all over the top of each other. And, turn a damned light on.
It is very common for relay modules to be active LOW, ie the relay is turned on when its input is taken LOW. Is that your problem ?
It is impossible to determine from your picture exactly how anything is wired. Please post a picture of a simple hand drawn circuit diagram.
It looks like you are using an ESP8266 which, I believe, has a 3.3V output. Can you please confirm that
