Relay driver shield for 24 relays (or more)?
for my current project (a remote antenna and bandpass filter switch) I need to drive at least 24 relays.
In my third prototype I use 2 4x4 driver shields.
But isn't there a cheaper way? Or should I go the resistor-transistor-diode route?
Relays are 12v (13.8v) and are at some 5m away from the Arduino which is continuously connected to my pc.
Any suggestions are welcome!
check - RELAY8 8-Channel Relay Driver Shield Quickstart Guide | Freetronics -
by using multiple shield you can drive up to 8x8 = 64 relays AFAIU
Thanks for the info Rob, but that would make it even more expensive than the 4x4 solution.
I'll probably have to develop my own board/shield :cold_sweat:
i want to know about how many or mximum relay we can drive with arduino uno.
