relay for arduino uno to control a 24 V actuator
Is there a relay I can use to control my actuator? The spec sheet is available on the following link:
(see page two for wire diagram)
If not, how can I use the adafruit mini feather relay on the arduino uno? what connections are needed to be made using jumper wires?
Thanks,
Malavika
Almost any relay can switch 24VAC. As long as the contacts are rated for your voltage and current it will be OK.
Yes, the Adafruit mini feather relay will work just fine. The Adafruit tutorial explains how to connect and gives you sample code to control it.
