relay help. digitalWrite high causing power off to device
I have a relay connected to a fan but when I do digitalWrite(fan, HIGH); it turns off. I think i have it connected to the relay correctly because when there is no power to the relay the fan is off(normally open?). When I execute digitalWrite(fan, LOW) it comes on. Not sure what I'm missing so any help is appreciated
int fan = 7;
// the setup routine runs once when you press reset:
// initialize the digital pin as an output.
pinMode(fan, OUTPUT);
// the loop routine runs over and over again forever:
if (Serial.available() > 0) {
int inByte = Serial.read();
switch (inByte) {
case 'y':
Serial.println("y was pressed");
case 'n':
digitalWrite(fan, LOW);
Serial.println("n was pressed");
default:
Show us a picture or draw us a schematic how things are wired.
thank you for the reply.
After further reading, I do have it hooked up correctly. I was just misunderstanding how the circuit works. When there is voltage to the 7 pin then the circuit is not complete. When I issue a LOW command that lets the circuit complete causing 5v to go to the relay and switch on
