Relay in on state as default?
So guys
I just finished my first home automation  but after some days I had come to Problem that after a power failure my relay doesn't on automatically.
So was thinking to set the relay state default to on.
Here is my sketch. Can u pls guide me how am I able to set relay on as default
[code#include <SPI.h>
#include <Ethernet.h>
#include <Servo.h>
int led = 4;
Servo microservo;
int pos = 0;
byte mac[] = { 0xDE, 0xAD, 0xBE, 0xEF, 0xFE, 0xED };   //physical mac address
byte ip[] = { 192, 168, 1, 178 };                      // ip in lan (that's what you need to use in your browser. ("192.168.1.178")
byte gateway[] = { 192, 168, 1, 1 };                   // internet access via router
byte subnet[] = { 255, 255, 255, 0 };                  //subnet mask
EthernetServer server(80);                             //server port
String readString;
   while (!Serial) {
    ; // wait for serial port to connect. Needed for Leonardo only
  pinMode(led, OUTPUT);
  microservo.attach(7);
  // start the Ethernet connection and the server:
  Ethernet.begin(mac, ip, gateway, subnet);
  server.begin();
  Serial.print("server is at ");
  Serial.println(Ethernet.localIP());
  // Create a client connection
  if (client) {
    while (client.connected()) {
      if (client.available()) {
        char c = client.read();
        //read char by char HTTP request
        if (readString.length() < 100) {
          //store characters to string
          readString += c;
          //Serial.print(c);
         //if HTTP request has ended
         if (c == '\n') {
           Serial.println(readString); //print to serial monitor for debuging
           client.println("HTTP/1.1 200 OK"); //send new page
           client.println("Content-Type: text/html");
           client.println();
           client.println("<HTML>");
           client.println("<HEAD>");
           client.println("<meta name='apple-mobile-web-app-capable' content='yes' />");
           client.println("<meta name='apple-mobile-web-app-status-bar-style' content='black-translucent' />");
           client.println("<link rel='stylesheet' type='text/css' href='http://randomnerdtutorials.com/ethernetcss.css' />");
           client.println("<TITLE>Random Nerd Tutorials Project</TITLE>");
           client.println("</HEAD>");
           client.println("<BODY>");
           client.println("<H1>Random Nerd Tutorials Project</H1>");
           client.println("<hr />");
           client.println("
           client.println("<H2>Arduino with Ethernet Shield</H2>");
           client.println("
           client.println("<a href=\"/?button1on\"\">Turn On LED</a>");
           client.println("<a href=\"/?button1off\"\">Turn Off LED</a>
           client.println("
           client.println("
           client.println("<a href=\"/?button2on\"\">Rotate Left</a>");
           client.println("<a href=\"/?button2off\"\">Rotate Right</a>
           client.println("<p>Created by Rui Santos. Visit http://randomnerdtutorials.com for more projects!</p>");
           client.println("
           client.println("</BODY>");
           client.println("</HTML>");
           delay(1);
           //stopping client
           client.stop();
           //controls the Arduino if you press the buttons
           if (readString.indexOf("?button1on") >0){
               digitalWrite(led, HIGH);
           if (readString.indexOf("?button1off") >0){
               digitalWrite(led, LOW);
           if (readString.indexOf("?button2on") >0){
                for(pos = 0; pos < 180; pos += 3)  // goes from 0 degrees to 180 degrees
                {                                  // in steps of 1 degree
                  microservo.write(pos);              // tell servo to go to position in variable 'pos'
                  delay(15);                       // waits 15ms for the servo to reach the position
           if (readString.indexOf("?button2off") >0){
                for(pos = 180; pos>=1; pos-=3)     // goes from 180 degrees to 0 degrees
            //clearing string for next read
            readString="";
Thanks in advance
How does "Rotate Left" equate to button2on? How does "Rotate Right" equate to button2off? The names are not magical. Make them make sense!
Where is the relay connected? To the ledPin? Why?
PaulS:
Rotate left or right activate when I click on button but I want to activate relay by default
Some relays have a "normally open" contact in addition to a "normally closed" contact.
The normally closed contact will be "on by default", and turned off when the relay coil is energised.
Fine. You have our permission. If you need help, you have to answer the questions.
michinyon:
ohh I forgot about it must looks like I had to make some changes in my relay board
Perhaps somewhere in the Setup() you can put something that turns the relay on... I can't figure out where you're controlling a relay in that code either.
PaulS:
Yes it is connected to led pin ? any issue ?
actually the code is from random nerds tutorial so i forgot to edit it fully
