Relay is not working (Urgent Assistance)
My relay is not functioning at all, it is a code error because it works with a simple code.
My relay is on pin 13 and my device is connected to the NO ( Normally Open), in the while loop I want the relay to close so I put digitalWrite(13, LOW); But it is not working at all.
Below is my code please try to assist
#include <SPI.h>
#include <Pixy2.h>
Pixy2 pixy;
// ENA IN1 IN2 IN3 IN4 ENB
int myPins[6] = {5, 6, 7, 8, 9, 10}; // all Digital pins from the motor driver
int enable1 = 5; // Motor Driver Enable 1
int enable2 = 10; // Motor Driver Enable 2
static int i=0;
int signature, x, y, width, height;
unsigned int newarea = 0;
Serial.print("Starting...\n");
// pixy.init();
pinMode(13, OUTPUT); // for the relay of the collection system
for (int i = 0; i < 6; i++) {
pinMode(myPins[i], OUTPUT);
pixy.init();
pixy.setLamp(0,0); // switching off the Pixy built in Lights
// digitalWrite(13,HIGH) ;
  // Detection system
uint16_t blocks;                               // Maximum number of blocks that getBlocks() will return.
blocks = pixy.ccc.getBlocks();                 //receive data from pixy
signature = pixy.ccc.blocks[i].m_signature;    //get object's signature
x = pixy.ccc.blocks[i].m_x;                    //get x position
y = pixy.ccc.blocks[i].m_y;                    //get y position
width = pixy.ccc.blocks[i].m_width;            //get width
height = pixy.ccc.blocks[i].m_height;          //get hight
if(signature == 1) {
// digitalWrite(13,LOW) ;
delay(350);
digitalWrite(enable1, LOW);
digitalWrite(enable2, LOW);
delay(30);
moveRobot(-110,0);
delay(500); // time to centre the robot to the ball
// code of area
newarea = width * height; //calculate the object area
Serial.print(newarea); // print area of the ball
Serial.print('\n');
while (newarea < 3000 && signature == 1)//go forward if object too small
// delay(10);
digitalWrite(13,LOW) ; // Start the vacume
moveRobot(100,100);                              //go forward
delay (10);
height = pixy.ccc.blocks[i].m_height;          //get Height
      Serial.print(newarea);                   // print signature area
 //     Serial.print("NEXT --->");
      Serial.print('\n');
  delay (50);
   //digitalWrite( 13,LOW) ;
// delay (10);
   delay (5000) ; // time for collection system to work
else {
digitalWrite(13,HIGH) ; // Start the vacume
moveRobot(140,0); // keep searching in circle for the ball
delay (10);
void moveRobot(int leftSpeed, int rightSpeed)
if (leftSpeed >= 0) {
digitalWrite(myPins[1], 0);
digitalWrite(myPins[2], 1);
else {
digitalWrite(myPins[1], 1);
digitalWrite(myPins[2], 0);
if (rightSpeed >= 0) {
digitalWrite(myPins[3], 0);
digitalWrite(myPins[4], 1);
else {
digitalWrite(myPins[3], 1);
digitalWrite(myPins[4], 0);
analogWrite(myPins[0], abs(leftSpeed));
analogWrite(myPins[5], abs(rightSpeed));
Could you edit your post to put you code in code tags?
As Idahowalker said.
You have part of the code in code tags (the shaded parts) but not all . Makes trying to make sense of your code very difficult.
Have you tried troubleshooting your code? I would start with the minimum code you can (i.e. with all but one feature commented out) Get that running then add little by little the remaining functions.
In the code you posted in the while loop,
digitalWrite(13,low) is commented out
digitalWrite(13,high) is still there?
Some relays boards are working inverted as there is an open collector circuit driving the relay.
Second point: how do you feed your relay, it could be that you are overcharging your board with the current drawn by the relay coil.
using </>
suggest using unique serial.prints to verify when calls to digitalWrite (13 are made. start with the basics
This all depends on how you have wired the relay module (high side/low side) and how, if any, you have set the jumper(s).
Pin 13 is not an ideal choice with the Uno/Nano etc because this is also the built in LED pin which flashes at system start.
Thank you all for the responses.
This is the cleaned code below and also I taged it.
In line 31 I set the relay to off digitalWrite(13, HIGH) ;
Then in line 69 inside the while loop once the statement is true the first line of code is to set the relay to 1 by using digitalWrite(13, LOW) ;
Then in line 94 once the while loop is done I set it to zero by digitalWrite(13, HIGH) ;
Also in line 99 in the else of the IF statement I set it to zero by digitalWrite(13,HIGH) ;
My relay is power on from the 5V pin from the Arduino (it is the only pin of the 5v) and the IN1 on pin 13, Ground on a GND pin from the Arduino and the connected device to the relay has its own power source.
Moreover, the relay is not broken, as I have tried a smaller blink code on it and it is working perfectly.
I don't understand why no signal is given out by PIN 13 in my code in the while or outside the while
#include <SPI.h>
#include <Pixy2.h>
Pixy2 pixy;
static int i=0;
int vac = 13;
  //  pixy.init();
  pixy.init();
     digitalWrite(13,HIGH) ;   // to set the relay to 0 from the begining
      // Detection system
  delay(350);
  delay(30);
   moveRobot(-110,0);
  //  code of area
          Serial.print('\n');
      //  delay(10);
    delay (10);
          Serial.print('\n');
      delay (50);
 //  delay (10);
  else   {
  delay (10);
  else {
  else {
Have you tried
      // Detection system
    //uint16_t blocks;                               // Maximum number of blocks that getBlocks() will return.
    //blocks = pixy.ccc.getBlocks();                 //receive data from pixy
    //signature = pixy.ccc.blocks[i].m_signature;    //get object's signature
    //x = pixy.ccc.blocks[i].m_x;                    //get x position
    //y = pixy.ccc.blocks[i].m_y;                    //get y position
    //width = pixy.ccc.blocks[i].m_width;            //get width
   // height = pixy.ccc.blocks[i].m_height;          //get hight
  //if(signature == 1) {
  //delay(350);
  //digitalWrite(enable1, LOW);
  //digitalWrite(enable2, LOW);
  //delay(30);
   //moveRobot(-110,0);
  //delay(500); // time to centre the robot to the ball
  //  code of area
     //     newarea = width * height; //calculate the object area
       //   Serial.print(newarea); // print area of the ball
         // Serial.print('\n');
  // while (newarea < 3000 && signature == 1)//go forward if object too small
      //  delay(10);
    ///moveRobot(100,100);                              //go forward
    //delay (10);
 //   x = pixy.ccc.blocks[i].m_x;                    //get x position
   // width = pixy.ccc.blocks[i].m_width;            //get width
    //height = pixy.ccc.blocks[i].m_height;          //get Height
    //newarea = width * height;                      //calculate the object area
       //   Serial.print(newarea);                   // print signature area
          //Serial.print('\n');
   //   delay (50);
      // digitalWrite(enable1, LOW);
      // digitalWrite(enable2, LOW);
 //  delay (10);
  //else   {
     //      digitalWrite(13,HIGH) ;                       // Start the vacume
// moveRobot(140,0); // keep searching in circle for the ball
  //delay (10);
delay(5000); //<<< used for trouble shooting.
Does that enable/disable the relay?
How is that supposed to work?
Hi @ zyadessam,
I don't know if I'm correct, but you are including the SPI library.
If you are using UNO, then SPI uses pin 13 and it is not recommended that you connect the relay to pin 13.
RV mineirin
Welcome to the forum.
What model Arduino are you using?
Can you please post a circuit diagram?
Just a hand drawn picture would be fine.
Thanks.. Tom... :smiley: :+1: :coffee: :australia:
