so I've got some 3wire 5v arduino relays that im trying to wire to boost the power sent to 2 servos, my professor suggested it. It seems like no matter how I wire it it doesn't work, any suggestions? >:(
Show us a good schematic of your circuit.
Show us a good image of your ‘actual’ wiring.
Give links to components.
Posting images:
https://forum.arduino.cc/index.php?topic=519037.0
Use CTRL T to format your code.
Attach your ‘complete’ sketch between code tags, use the </> icon in the posting menu.
[code]Paste your sketch here[/code]
What is an Arduino relay ??? ?
What are you actually trying to do with the relays. What are the relays switching? No relay is going to boost power to anything on its own.
Steve
What's a 3-wire relay? Relays have a minimum of 4 wires.
Connecting things at random without knowing what you are doing is likely to damage components.
Ya know , I've been wondering the same thing since 2013 when I first discovered arduinos.
scruffmcgruff:
Replacement professor? ![]()
