Relay not deactivating according to the preferred PSI
Hi there,
I am currently busy with a project that uses solenoids being activated by relays and deactivates when preferredPSI is reached, when pressing key A the code works correctly by deactivating when preferredPSI_A is reached, but when I press key B or C the relays deactivate when preferredPSI_A is reached and not preferredPSI_B or C as per the code. If there is anyone that can assist me it will be highly appreciated. See code below.
if (key){
    Serial.print(key);
    switch (key) {
      case 'A':
      digitalWrite(relayPin1, LOW);
      digitalWrite(relayPin3, LOW);
      digitalWrite(relayPin5, LOW);
      digitalWrite(relayPin7, LOW);
      case 'B':
      case 'C':
      case 'D':
      digitalWrite(relayPin2, LOW);
      digitalWrite(relayPin4, LOW);
      digitalWrite(relayPin6, LOW);
      digitalWrite(relayPin8, LOW);
      /*default:
      break;*/
      // AA //
  if (pressureValue1 >= preferredPSI_A1){
    digitalWrite(relayPin1, HIGH);
  if (pressureValue2 >= preferredPSI_A2){
    digitalWrite(relayPin3, HIGH);
  if (pressureValue3 >= preferredPSI_A3){
    digitalWrite(relayPin5, HIGH);
  if (pressureValue4 >= preferredPSI_A4){
    digitalWrite(relayPin7, HIGH);
      // BB //
  if (pressureValue1 >= preferredPSI_B1){
  if (pressureValue2 >= preferredPSI_B2){
  if (pressureValue3 >= preferredPSI_B3){
  if (pressureValue4 >= preferredPSI_B4){
      // CC //
  if (pressureValue1 >= preferredPSI_C1){
  if (pressureValue2 >= preferredPSI_C2){
  if (pressureValue3 >= preferredPSI_C3){
  if (pressureValue4 >= preferredPSI_C4){
      // DD //
  if (pressureValue1 <= preferredPSI_D1){
    digitalWrite(relayPin2, HIGH);
  if (pressureValue2 <= preferredPSI_D2){
    digitalWrite(relayPin4, HIGH);
  if (pressureValue3 <= preferredPSI_D3){
    digitalWrite(relayPin6, HIGH);
  if (pressureValue4 <= preferredPSI_D4){
    digitalWrite(relayPin8, HIGH);
Use serial monitor and Serial.println of strategic internal variables. That's debugging, very useful!
Post the complete code, a detailed description of what it is supposed to do and a diagram showing how components are connected to Arduino (which Arduino?) and each other.
When testing the code, use an LED with a series resistor to indicate relay action, instead of the actual relay. That avoids power supply and wiring problems.
Hi I am using an Arduino Mega, it is suppose to run my air ride on my car. All inputs and outputs is connected to the Arduino Mega with only the 8 channel relay module board getting power from an external source to power up the relay module, the screen and pressure transducers is getting power from the Arduino Mega. I am using a 4x4 keypad with A, B, C and D keys as presets and the rest of the keys controlling the relays individually. See below complete code.
#include <Keypad.h>
const byte ROWS = 4; // Four rows
const byte COLS = 4; // Four columns
char keys[ROWS][COLS] = {
  {'1','2','3','A'},
  {'4','5','6','B'},
  {'7','8','9','C'},
  {'*','0','#','D'}
byte rowPins[ROWS] = {22, 23, 24, 25}; // Connect to the row pinouts of the keypad
byte colPins[COLS] = {26, 27, 28, 29}; // Connect to the column pinouts of the keypad
Keypad keypad = Keypad(makeKeymap(keys), rowPins, colPins, ROWS, COLS);
/////// REMOTE ///////
#include <RemoteControl.h>
#include "RemoteReceiver.h"
const int pinD0D = A9; // Connect to D0 on the receiver Button D
const int pinD1C = A8; // Connect to D1 on the receiver Button C
const int pinD2B = A7; // Connect to D2 on the receiver Button B
const int pinD3A = A6; // Connect to D3 on the receiver Button A
const int pinVT = A5; // Connect to VT on the receiver Learn
/////// SCREEN ///////
#include <Adafruit_GFX.h>       // include Adafruit graphics library
#include <Adafruit_SSD1306.h>   // include Adafruit SSD1306 OLED library
#include <SPI.h>
#include <Wire.h>
#define SCREEN_WIDTH 128
#define SCREEN_HEIGHT 64
#define OLED_RESET 4 // Reset pin # (or -1 if sharing Arduino reset pin)
#define BLACK   0
#define WHITE   1
// Declaration for SSD1306 display connected using software SPI (default case):
#define OLED_MOSI   51
#define OLED_CLK   52
#define OLED_DC    48
#define OLED_CS    53
#define OLED_RESET 44
Adafruit_SSD1306 display(SCREEN_WIDTH, SCREEN_HEIGHT,
  OLED_MOSI, OLED_CLK, OLED_DC, OLED_RESET, OLED_CS);
const unsigned long interval = 1000; // Time interval between pressure readings in milliseconds
unsigned long previousMillis = 0; // Variable to store the last time pressure was read
unsigned long previousDisplayMillis = 0; // Variable to store the last time the display was updated
unsigned long displayInterval = 1000; // Interval for updating the display in milliseconds
/////// PRESSURE ///////
const int pressureInput1 = A4; // Analog pin for pressure sensor A1
const int pressureInput2 = A1;
const int pressureInput3 = A2;
const int pressureInput4 = A3;
const int pressureInput5 = A0;
// Define your preferred PSI thresholds for each pressure sensor
int preferredPSI_A1 = 30; // Adjust this value according to your requirements
int preferredPSI_A2 = 30;
int preferredPSI_A3 = 50;
int preferredPSI_A4 = 50;
int preferredPSI_B1 = 40;
int preferredPSI_B2 = 40;
int preferredPSI_B3 = 50;
int preferredPSI_B4 = 50;
int preferredPSI_C1 = 60;
int preferredPSI_C2 = 60;
int preferredPSI_C3 = 70;
int preferredPSI_C4 = 70;
const int preferredPSI_D1 = 0;
const int preferredPSI_D2 = 0;
const int preferredPSI_D3 = 0;
const int preferredPSI_D4 = 0;
float pressureValue1 = 0; //variable to store the value coming from the pressure transducer
float pressureValue2 = 0;
float pressureValue3 = 0;
float pressureValue4 = 0;
float pressureValue5 = 0;
const int pressureZero = 102; //analog reading of pressure transducer at 0psi       102.4
const int pressureMax = 921; //analog reading of pressure transducer at 200psi      921.6
const int pressuretransducermaxPSI = 200; //psi value of transducer being used
// Function to check if pressure exceeds the preferred PSI
/*bool pressureExceedsThreshold(int pin, int preferredPSI_A1) {
   pressureValue1 = analogRead(pin);
  return pressureValue1 >= preferredPSI_A1;
/////// RELAYS /////////
byte relayPin1 = 9;
byte relayPin2 = 8;
byte relayPin3 = 7;
byte relayPin4 = 6;
byte relayPin5 = 5;
byte relayPin6 = 4;
byte relayPin7 = 3;
byte relayPin8 = 2;
  Serial.begin(9600); // Initialize serial communication
  // Rotate the display 90 degrees (clockwise)
  display.setRotation(1);
  // SSD1306 display setup
  if(!display.begin(SSD1306_SWITCHCAPVCC, 0x3C)) { // Address 0x3C for 128x64
    Serial.println(F("SSD1306 allocation failed"));
    for(;;);
  pinMode(pinD0D, INPUT);
  pinMode(pinD1C, INPUT);
  pinMode(pinD2B, INPUT);
  pinMode(pinD3A, INPUT);
  pinMode(pinVT, INPUT);
  pinMode(relayPin1, OUTPUT);
  pinMode(relayPin2, OUTPUT);
  pinMode(relayPin3, OUTPUT);
  pinMode(relayPin4, OUTPUT);
  pinMode(relayPin5, OUTPUT);
  pinMode(relayPin6, OUTPUT);
  pinMode(relayPin7, OUTPUT);
  pinMode(relayPin8, OUTPUT);
     // Initialize relays to OFF state
  keypad.addEventListener(keypadEvent);
  char key = keypad.getKey(); // Check for a keypress
  unsigned long currentMillis = millis(); // get the current time
  // Check if the specified interval has passed since the last pressure reading
  if (currentMillis - previousMillis >= interval) {
    previousMillis = currentMillis; // Save the current time for the next interval
    // Read pressure values
    pressureValue1 = analogRead(pressureInput1);
    pressureValue1 = ((pressureValue1 - pressureZero) * pressuretransducermaxPSI) / (pressureMax - pressureZero);
    pressureValue2 = analogRead(pressureInput2);
    pressureValue2 = ((pressureValue2 - pressureZero) * pressuretransducermaxPSI) / (pressureMax - pressureZero);
    pressureValue3 = analogRead(pressureInput3);
    pressureValue3 = ((pressureValue3 - pressureZero) * pressuretransducermaxPSI) / (pressureMax - pressureZero);
    pressureValue4 = analogRead(pressureInput4);
    pressureValue4 = ((pressureValue4 - pressureZero) * pressuretransducermaxPSI) / (pressureMax - pressureZero);
    pressureValue5 = analogRead(pressureInput5);
    pressureValue5 = ((pressureValue5 - pressureZero) * pressuretransducermaxPSI) / (pressureMax - pressureZero);
    // Check if the display update interval has passed
  if (currentMillis - previousDisplayMillis >= displayInterval) {
    previousDisplayMillis = currentMillis; // Save the current time for the next display update
    // Display pressure readings
    display.clearDisplay(); // Clear the display buffer
    // LF
    display.setTextSize(1);
    display.setTextColor(WHITE);
    display.setCursor(10, 5);
    display.println("LF");
    display.setCursor(4, 25);
    display.print(" ");
    display.println(pressureValue1, 0);
    //Serial.print(pressureValue1);
    //Serial.print(" ");
    // RF
    display.setCursor(45, 5);
    display.println("RF");
    display.setCursor(39, 25);
    display.print(" ");
    display.println(pressureValue2, 0);
    //Serial.print(pressureValue2);
    // LR
    display.setCursor(10, 50);
    display.println("LR");
    display.setCursor(4, 70);
    display.print(" ");
    display.println(pressureValue3, 0);
    //Serial.print(pressureValue3);
    // RR
    display.setCursor(45, 50);
    display.println("RR");
    display.setCursor(39, 70);
    display.print(" ");
    display.println(pressureValue4, 0);
    //Serial.println(pressureValue4);
    // TANK
    display.setCursor(22, 90);
    display.println("TANK");
    display.setCursor(22, 110);
    display.print(" ");
    display.println(pressureValue5, 0);
    display.display(); // Display the content in the buffer
void keypadEvent(KeypadEvent key){
    switch (keypad.getState()){
    case PRESSED:
        if (key == '1') {
            digitalWrite(relayPin1,LOW);
    case RELEASED:
        if (key == '1') {
            digitalWrite(relayPin1,HIGH);
      /* FRONT UP */
    case PRESSED:
        if (key == '2') {
            digitalWrite(relayPin3,LOW);
    case RELEASED:
        if (key == '2') {
            digitalWrite(relayPin3,HIGH);
    case PRESSED:
        if (key == '3') {
    case RELEASED:
        if (key == '3') {
    case PRESSED:
        if (key == '4') {
            digitalWrite(relayPin2,LOW);
    case RELEASED:
        if (key == '4') {
            digitalWrite(relayPin2,HIGH);
        /* FRONT DOWN */
    case PRESSED:
        if (key == '5') {
            digitalWrite(relayPin4,LOW);
    case RELEASED:
        if (key == '5') {
            digitalWrite(relayPin4,HIGH);
    case PRESSED:
        if (key == '6') {
    case RELEASED:
        if (key == '6') {
    case PRESSED:
        if (key == '7') {
            digitalWrite(relayPin5,LOW);
    case RELEASED:
        if (key == '7') {
            digitalWrite(relayPin5,HIGH);
        /* REAR UP */
    case PRESSED:
        if (key == '8') {
            digitalWrite(relayPin7,LOW);
    case RELEASED:
        if (key == '8') {
            digitalWrite(relayPin7,HIGH);
    case PRESSED:
        if (key == '9') {
    case RELEASED:
        if (key == '9') {
    case PRESSED:
        if (key == '*') {
            digitalWrite(relayPin6,LOW);
    case RELEASED:
        if (key == '*') {
            digitalWrite(relayPin6,HIGH);
        /* REAR DOWN */
    case PRESSED:
        if (key == '0') {
            digitalWrite(relayPin8,LOW);
    case RELEASED:
        if (key == '0') {
            digitalWrite(relayPin8,HIGH);
    case PRESSED:
        if (key == '#') {
    case RELEASED:
        if (key == '#') {
  // Check if key 'A', 'B', 'C' & 'D' is pressed and the pressure is below the preferred PSI
  if (key){
    //Serial.print("Received key: ");
    Serial.print(key);
    switch (key) {
      case 'A':
      case 'B':
      case 'C':
      case 'D':
      /*default:
      break;*/
      // AA //
    Serial.print(preferredPSI_A1);
    Serial.print(", ");
    Serial.print(preferredPSI_A2);
    Serial.print(", ");
    Serial.print(preferredPSI_A3);
    Serial.print(", ");
    Serial.print(preferredPSI_A4);
    Serial.print(", ");
      // BB //
    Serial.print(preferredPSI_B1);
    Serial.print(", ");
    Serial.print(preferredPSI_B2);
    Serial.print(", ");
    Serial.print(preferredPSI_B3);
    Serial.print(", ");
    Serial.print(preferredPSI_B4);
    Serial.print(", ");
      // CC //
    Serial.print(preferredPSI_C1);
    Serial.print(", ");
    Serial.print(preferredPSI_C2);
    Serial.print(", ");
    Serial.print(preferredPSI_C3);
    Serial.print(", ");
    Serial.print(preferredPSI_C4);
    Serial.print(", ");
      // DD //
    Serial.print(preferredPSI_D1);
    Serial.print(", ");
    Serial.print(preferredPSI_D2);
    Serial.print(", ");
    Serial.print(preferredPSI_D3);
    Serial.print(", ");
    Serial.println(preferredPSI_D4);
please, link for these 2 libraries:
Hi, GitHub - zwb800/RemoteControl: Arduino PT2262 or Ev1527 Receiver Library and GitHub - chrisandreae/RemoteReceiver: Arduino library for receiving data from wireless remote controls with an EV1527 or similar chipset.
