Relay not following code
Hello,
I have connected two solenoid valves (12V DC) to a 2 channel Songle relay. The relay supports the power supply we want to give to the solenoids and the code is simple so I am surprised with the problems we're having. We have correctly connected the circuit as far as the NC/NO is concerned.
We wrote a simple code to turn solenoid 1 on for 5 seconds. Have both solenoids off for 5 seconds. Then turn solenoid 2 on for 5 seconds. Then have both solenoids off for 5 seconds.
For some reason the solenoids kept on overlapping and not following the commands we gave it.
I am a bit confused as to why this might be.
If anyone has had similar experiences or could shed some light on this I would appreciate it!
Welcome to the Forum. Without seeing your code, all we can do is wildly guess. Please read the two posts at the top of this Forum by Nick Gammon on guidelines for posting here, especially the use of code tags which make the code looklike thiswhen posting source code files. Also, before posting the code, use Ctrl-T in the IDE to reformat the code in a standard format, which makes it easier for us to read.
I look forward to seeing the code as it should be very simple to do what you want. How is everything powered ? Are you driving the relays directly from the Arduino or via a transistor using a power supply external to the Arduino ?
OK, Aarg.. understood. I'll make sure to always post the code in the future and gave the guidelines a read through.
I am powering the arduino from the computer USB and we have an external power source (12V 1A - like the solenoids) that is powering the solenoids. We want the arduino to tell the relay when to close the circuit allowing the 12V current to power the solenoids.
We have the solenoid circuit connected to the COM and NO on the relay.
Obviously solenoids can be a little temperamental and can sometimes not shut exactly when you want them to depending on pressure and so on.. We can put this hypothesis to one side as the relay has 2 little lights that tell you when each channel is connecting. These lights do not follow the code and were on at the same time sometimes.
I'm not sure why this is happening.. should be a very simple operation but for some reason it isnt quite working.
When we adjusted the code so that just one channel would switch on and off this worked fine...
int relay1 = 11;
int relay2 = 10;
  pinMode(relay1, OUTPUT);
  pinMode(relay2, OUTPUT);
  digitalWrite(relay1, LOW);
  digitalWrite(relay2, LOW);
  digitalWrite(relay1, HIGH);
  delay(5000);
  delay(5000);
  digitalWrite(relay2, HIGH);
  delay(5000);
  delay(5000);
Relay_solenoid_sketch.ino (431 Bytes)
That's just a snippet. Please post the entire sketch. Also a schematic.
willacker:
Even "simple operation" may be tricky, if you
  • don't know how things are working
  • or if if think that things are working different than they actually do
So please check:
Hardware used? Many ready-made relay boards provide a "active LOW" switching logik, meaning:
  • relay pin set to INPUT (HIGH or LOW) ==> relay NOT switched
  • relay pin set to OUTPUT/HIGH ==> relay NOT switched
  • relay pin set to OUTPUT/LOW ==> relay switched
So a correct setup for an "active LOW" relay board, with relays not switching at power-on would look like:
  pinMode(relay1, INPUT_PULLUP);
  pinMode(relay2, INPUT_PULLUP);
Otherwise the relay may switch or click-switch at setup.
The next thing is "switching inductive DC load".
If you are switching a DC valve, this is an "inductive DC load", and a correct hardware wiring would require a "freewheel diode" in your circuit.
Do you have those "freewheel diodes" in your solenoid circuits?
Hi Jurs,
That is a very helpful and constructive reply.
I will def give this a try tomorrow and see how it goes.. I am using a songle relay that is part of preassembled board so this may well be the case.
Also, we don't have a freewheel diode in our circuit.. will look into this also!
Will give you an update when I have tried out your advice.. thanks again!
