Relay not turning coffee maker on
I was recently gifted a SainSmart 2 relay board but I can not get anything to turn on with the relay. It does work when plugged directly to the outlet. I have VCC to 5V, GRD to Ground and IN1 to 8. The relay turns on, I can hear it and the LED turns on. I don't have specs on the coffee pot as its just some no name generic coffee maker with nothing more than an off switch, pump and heating element. I have tried other, less power intensive things as well and they do not turn on either. The power strip I cut to plug the coffee make in was working before I cut it. I am out of ideas
  pinMode(8, OUTPUT);// put your setup code here, to run once:
digitalWrite(8, HIGH);
digitalWrite(8, LOW);
delay(2000);
delay(2000);// put your main code here, to run repeatedly:
So you hear the relay click, and see the LED on the relay board turn on/off.
And you only have only cut the phase (brown) wire in the power strip.
And connected those two cut ends to the relay board.
To pin1 and pin2, counting from the side of the relay board.
Silkscreen is confusing there. Schematic is not.
Leo..
See THIS: and scroll down to info on relay contacts.
