Hello everyone.
I have hit a dead end and struggle to find an explanation for the problem I am facing.
I am working on a larger project, where I mix water with powder. Everything is weighed, measured etc. To test my software while I am working on the hardware in parallel, I use smaller sketches which I then later transfer into the "overall" sketch.
Everything worked fine and I am very close to the finish line, where I face a problem that I have not faced before.
In my "smaller" (in terms of byte and lines) sketch my relays turn on accordingly and everything works.
In my "larger" sketch. I get the same result, however one of the relays gets the signal but does not switch (led on relay is switched on but dimmed). That indicates to me, that it doesn't get enough Voltage. However, it is only one of the relays, the other one works perfectly fine, exchanging them gives me the same result but on the other relay. That proofs that the relays are intact, correctly connected and should be working. When switching to the smaller sketch, they both work fine again. I am using the same setup for both tests, which means all sensors etc. are connected when running both sketches.
I am using a Mega.
Has anyone experienced something similar?
Please see both the sketches below:
#include <FlowSensor.h>
#include <LcdBarGraph.h>
#include <LiquidCrystal.h>
#include "HX711.h"
//Internal NTC Stuff
const long int RT0 = 50000; // Ω
const int B = 3970; // K
const int VCC = 5; //Supply voltage
const long int R = 12000; //R=10KΩ
//Variables
float RT, VR, ln, TX, T0, VRT;
//DC Motor
const int DC_Motor = 6;
//Scale Back Left
#define LOADCELL_DOUT_PIN_1 22
#define LOADCELL_SCK_PIN_1 24
HX711 scale_1;
float calibration_factor_1 = -650;
//Scale Front Left
#define LOADCELL_DOUT_PIN_2 32
#define LOADCELL_SCK_PIN_2 33
HX711 scale_2;
float calibration_factor_2 = -800;
//Scale Back Right
#define LOADCELL_DOUT_PIN_3 25
#define LOADCELL_SCK_PIN_3 23
HX711 scale_3;
float calibration_factor_3 = -700;
//Scale Front Right
#define LOADCELL_DOUT_PIN_4 34
#define LOADCELL_SCK_PIN_4 35
HX711 scale_4;
float calibration_factor_4 = -740;
//Constants
const int One_Cycle = 6000;
const int Scale_Interval = 100;
const int Scale_Pause = One_Cycle - Scale_Interval;
const int Motor_Interval = 4000;
const int Motor_Pause = One_Cycle - Motor_Interval;
const int Desired_Weight = 14; // this is in the variables section in the overall sketch
byte DC_Motor_Status = LOW;
byte Scale_Status = LOW;
byte Powder_Status = LOW;
//Variables
float current_weight = 0;
float last_weight = 0; // not used in the sketch below
int last_volume; // not used in the sketch below
int last_temperature; // not used in the sketch below
unsigned long currentMillis = 0;
unsigned long previous_motor_Millis = 0;
unsigned long previous_scale_Millis = 0;
unsigned long previous_lcd_Millis = 0;
//Thermocouple Stuff
#include <SPI.h>
#include "Adafruit_MAX31855.h"
// Example creating a thermocouple instance with software SPI on any three
// digital IO pins.
#define MAXDO_1 31
#define MAXCS_1 30
#define MAXCLK_1 29
// initialize the Thermocouple
Adafruit_MAX31855 thermocouple_1(MAXCLK_1, MAXCS_1, MAXDO_1);
#define MAXDO_2 26
#define MAXCS_2 27
#define MAXCLK_2 28
Adafruit_MAX31855 thermocouple_2(MAXCLK_2, MAXCS_2, MAXDO_2);
//PID Stuff
#include <PID_v1.h>
#define RELAY_PIN 19
#define RELAY_ON HIGH
#define RELAY_OFF LOW
//Define Variables we'll be connecting to
double Setpoint, Input, Output;
//Specify the links and initial tuning parameters
double Kp = 30, Ki = 10, Kd = 100;
PID myPID(&Input, &Output, &Setpoint, Kp, Ki, Kd, DIRECT);
//WindowSize DON'T CHANGE FOR NOW!!!
int WindowSize = 250;
int WindowSize_Scale = 500;
int WindowSize_LCD = 300;
unsigned long windowStartTime;
unsigned long windowStartTime_Scale;
unsigned long windowStartTime_LCD;
//LCD
const int rs = 12, en = 11, d4 = 5, d5 = 4, d6 = 3, d7 = 2;
LiquidCrystal lcd(rs, en, d4, d5, d6, d7);
byte LCD_Columns = 20;
byte LCD_Rows = 4;
//Flow Sensor
FlowSensor Sensor(YFS201, 18);
unsigned long timebefore = 0; // same type as millis(), is not being used again in this sketch
const int Pump = 10;
int variables[2][2] = { { 0, 1 }, { 2, 50 } }; // I want to link to the array in the array that I setup in the Menu file
void count() {
Sensor.count();
//DC Motor
pinMode(DC_Motor, OUTPUT);
//Scale
scale_1.begin(LOADCELL_DOUT_PIN_1, LOADCELL_SCK_PIN_1);
scale_2.begin(LOADCELL_DOUT_PIN_2, LOADCELL_SCK_PIN_2);
scale_3.begin(LOADCELL_DOUT_PIN_3, LOADCELL_SCK_PIN_3);
scale_4.begin(LOADCELL_DOUT_PIN_4, LOADCELL_SCK_PIN_4);
scale_1.set_scale(calibration_factor_1); // this value is obtained by calibrating the scale with known weights; see the README for details
scale_2.set_scale(calibration_factor_2); // this value is obtained by calibrating the scale with known weights; see the README for details
scale_3.set_scale(calibration_factor_3); // this value is obtained by calibrating the scale with known weights; see the README for details
scale_4.set_scale(calibration_factor_4); // this value is obtained by calibrating the scale with known weights; see the README for details
scale_1.tare(); // reset the scale to 0
scale_2.tare(); // reset the scale to 0
scale_3.tare(); // reset the scale to 0
scale_4.tare(); // reset the scale to 0
//PID Stuff
windowStartTime = millis();
windowStartTime_Scale = millis();
windowStartTime_LCD = millis();
//initialize the variables we're linked to
Setpoint = 38; //Temperature is the Setpoint
//tell the PID to range between 0 and the full window size
myPID.SetOutputLimits(0, WindowSize);
myPID.SetSampleTime(WindowSize / 10); // make sure we measure and sample at least 10 times per WindowSize.
//turn the PID on
myPID.SetMode(AUTOMATIC);
//Thermocouple
thermocouple_1.begin();
thermocouple_2.begin();
//NTC
T0 = 25 + 273.15;
//Flowmeter
Sensor.begin(count);
//Flow Through Heater
pinMode(RELAY_PIN, OUTPUT);
//Pump
pinMode(Pump, OUTPUT);
//LCD
lcd.begin(20, 4);
currentMillis = millis();
Water_Dispensing();
Powder_Dispensing();
Update_LCD();
void Update_LCD() {
if (millis() - windowStartTime_LCD > WindowSize_LCD) { //time to shift the Relay Window
if (variables[0][0] < variables[1][1] || current_weight > (-1) * Desired_Weight) {
windowStartTime_LCD += WindowSize_LCD;
LcdBarGraph lbg0(&lcd, 19, 1, 1);
lcd.setCursor(6, 0);
lcd.print("PROGRESS");
lbg0.drawValue(variables[0][0], variables[1][1]);
// Volume Display
// Printing the Vol.: will always be called
lcd.setCursor(0, 2);
lcd.print("Vol.: ");
// Single digit volumes
if (variables[0][0] < 10) {
lcd.setCursor(8, 2);
lcd.print(variables[0][0]);
// Double digit volumes
if (variables[0][0] >= 10 && variables[0][0] < 100) {
lcd.setCursor(7, 2);
// Triple digit volumes
if (variables[0][0] >= 100) {
lcd.setCursor(6, 2);
// Powder Display
// Printing the Form.: will always be called
lcd.setCursor(0, 3);
lcd.print("Form.: ");
// Single digit Weight
if (current_weight * (-1) < 10) {
lcd.setCursor(8, 3);
lcd.print(current_weight * (-1), 0);
// Double digit Weight
if (current_weight * (-1) >= 10 && current_weight * (-1) < 100) {
lcd.setCursor(7, 3);
// Triple digit Weight
if (current_weight * (-1) >= 100) {
lcd.setCursor(6, 3);
// Water Temperature
// Printing the Temp.: will always be called
lcd.setCursor(11, 2);
lcd.print("Temp.: ");
// Single digit Temp
if (TX < 10) {
lcd.setCursor(19, 2);
lcd.print(TX, 0);
// Double digit Temp
if (TX >= 10 && TX < 100) {
lcd.setCursor(18, 2);
lcd.print(TX, 0);
// Triple digit Temp
if (TX >= 100) {
lcd.setCursor(17, 2);
lcd.print(TX, 0);
lcd.clear();
lcd.setCursor(5, 1);
lcd.print("PREPERATION");
lcd.print("DONE");
void Water_Dispensing() {
if (variables[0][0] < variables[1][1]) {
digitalWrite(Pump, HIGH);
Sensor.read();
variables[0][0] = Sensor.getVolume() * 1000;
Serial.print("Volume: ");
Serial.print(variables[0][0]);
Serial.print("ml --- ");
//Temperature NTC
VRT = analogRead(A15); //Acquisition analog value of VRT
VRT = (5.00 / 1023.00) * VRT; //Conversion to voltage
VR = VCC - VRT;
RT = VRT / (VR / R); //Resistance of RT
ln = log(RT / RT0);
TX = (1 / ((ln / B) + (1 / T0))); //Temperature from thermistor
TX = TX - 273.15; //Conversion to Celsius
Serial.print("NTC Temperature: ");
Serial.print(TX);
Serial.print(" [C] --- ");
//Thermocouple
double d = thermocouple_2.readCelsius();
Serial.print("FTH Control Temp. = ");
Serial.print(d);
Serial.print("[C]");
Input = TX;
myPID.Compute();
if (millis() - windowStartTime > WindowSize) { //time to shift the Relay Window
windowStartTime += WindowSize;
Serial.println("");
Serial.print("Relay Window shifted");
Serial.print(" --- Setpoint: ");
Serial.print(Setpoint);
Serial.print(" --- Output: ");
Serial.print(Output);
if (Output > millis() - windowStartTime) {
digitalWrite(RELAY_PIN, RELAY_ON);
Serial.print(" --- Relay ON ");
Serial.print(" --- Time: ");
Serial.print(millis());
Serial.println(" ms");
digitalWrite(RELAY_PIN, RELAY_OFF);
Serial.print(" --- Relay OFF");
digitalWrite(Pump, LOW);
void Powder_Dispensing() {
if (millis() - windowStartTime_Scale > WindowSize_Scale) { //time to read the scales and maybe change the motor status
windowStartTime_Scale += WindowSize_Scale;
Serial.println("");
Serial.print("Current dispensed weight: ");
current_weight = (scale_1.get_units(1) + scale_2.get_units(1) + scale_3.get_units(1) + scale_4.get_units(1));
Serial.print(current_weight, 0);
Serial.print(" [g]");
if (current_weight > (-1) * Desired_Weight && Powder_Status == LOW) {
digitalWrite(DC_Motor, HIGH);
Serial.println(" --- Motor ON");
digitalWrite(DC_Motor, LOW);
Powder_Status = HIGH;
Serial.print("Dispensing finished"); //for debugging
Serial.println(" --- Motor OFF");
And not working in this one (warning rather long):
//Included Libraries
//Sensors or Actuators
#include "HX711.h"
#include <SPI.h>
#include <EncoderButton.h>
//LCD Libraries
#include <LiquidMenu.h>
// Others
#include <EEPROM.h>
#include <PID_v1.h>
//PID
//Same for all PIDs
//Drink 1
double Setpoint_1, Input_1, Output_1;
PID myPID_1(&Input_1, &Output_1, &Setpoint_1, Kp, Ki, Kd, DIRECT);
double Setpoint_2, Input_2, Output_2;
PID myPID_2(&Input_2, &Output_2, &Setpoint_2, Kp, Ki, Kd, DIRECT);
double Setpoint_3, Input_3, Output_3;
PID myPID_3(&Input_3, &Output_3, &Setpoint_3, Kp, Ki, Kd, DIRECT);
//Dispensing Related
bool Powder_Status = LOW;
//Flow Sensor
//Pump
//DC Motor
//LCD
byte LCD_Rows = 4;
//EncoderButton(byte encoderPin1, byte encoderPin2, byte switchPin);
EncoderButton eb1(21, 20, 51);
bool eb1_update_executed = false;
bool switching_focus = true;
enum FunctionTypes {
increase = 1,
decrease = 2,
/* An enumerator can be used for the callback functions. It sets the number
* for similar functions. Later when a function is attached it can be passed
* with this enum rather than a magic number.
//NTC
//Variables
//Thermocouples
//Thermocouple_1
#define MAXDO_1 31
#define MAXCS_1 30
#define MAXCLK_1 29
//Thermocouple_2
#define MAXDO_2 26
#define MAXCS_2 27
#define MAXCLK_2 28
//LED
//LED definition
int ledPin = 45;
//LED Variables
bool led_status = 1;
char led_status_text[4];
char led_on[] = " ON"; //There is a syntax error here
char led_off[] = "OFF"; //There is a syntax error here
int ledvalue = 1;
long ledtime = 0;
int ledperiode = 1250;
//Speaker
//Speaker definition
int speakerPin = 13;
// Tone definition
bool tones_status = 1;
int tones_duration = 25;
char tones_status_text[4];
char tones_on[] = " ON";
char tones_off[] = "OFF";
int numTones = 10;
int tones[] = { 261, 277, 294, 311, 330, 349, 370, 392, 415, 440 };
// mid C C# D D# E F F# G G# A
//Scales
//Scale Back Left
HX711 scale_1;
//Scale Front Left
HX711 scale_2;
//Scale Back Right
HX711 scale_3;
//Scale Front Right
HX711 scale_4;
//Dispensing and Menu Variables
int variables[14][6] = {
// 0, 1 , 2, 3, 4, 5}
/*0*/ { 0, 250, 10, 5, 0, 0 }, // Drink_1 Actual Water Amount, Max. Water, Min. Water, Increment, Drink_1_Water_ee_address, Current Water Amount
/*1*/ { 0, 90, 25, 1, 2, 0 }, // Drink_1 Actual Water Temp, Max. Water Temp, Min. Water Temp, Increment, Drink_1_Water_Temp_ee_address, Current Water Temp.
/*2*/ { 0, 100, 0, 1, 4, 0 }, // Drink_1 Actual Powder Amount, Max. Powder Amount, Min. Powder Amount, Increment, Drink_1_Powder_ee_address, Current Powder Amount
/*3*/ { 0, 250, 25, 1, 6, 0 }, // Drink_2 Actual Water Amount, Max. Water, Min. Water, Increment, Drink_2_Water_ee_address, Current Water Amount
/*4*/ { 0, 90, 25, 1, 8, 0 }, // Drink_2 Actual Water Temp, Max. Water Temp, Min. Water Temp, Increment, Drink_1_Water_Temp_ee_address, Current Water Temp.
/*5*/ { 0, 100, 0, 1, 10, 0 }, // Drink_2 Actual Powder Amount, Max. Powder Amount, Min. Powder Amount, Increment, Drink_2_Powder_ee_address, Current Powder Amount
/*6*/ { 0, 250, 10, 5, 12, 0 }, // Drink_3 Actual Water Amount, Max. Water, Min. Water, Increment, Drink_2_Water_ee_address, Current Water Amount
/*7*/ { 0, 90, 25, 1, 14, 0 }, // Drink_3 Actual Water Temp, Max. Water Temp, Min. Water Temp, Increment, Drink_1_Water_Temp_ee_address, Current Water Temp.
/*8*/ { 0, 100, 0, 1, 16, 0 }, // Drink_3 Actual Powder Amount, Max. Powder Amount, Min. Powder Amount, Increment, Drink_2_Powder_ee_address, Current Powder Amount
/*9*/ { 0, 1, 0, 0, 18, 0 }, // Tone Settings
/*10*/ { 0, 1, 0, 0, 20, 0 }, // LED Settings
/*11*/ { 0, 10, 0, 1, 22, 0 },
/*12*/ { 0, 10, 0, 1, 24, 0 },
/*13*/ { 0, 10, 0, 1, 26, 0 },
float temp_variables_2_5;
//Variables Tables for quicker reference
//Drink 1
//Variable 0 : Drink 1 Water Amount ------- Array : [0][0]
//Variable 1 : Drink 1 Water Temperature -- Array : [1][0]
//Variable 2 : Drink 1 Powder Amount ----- Array : [2][0]
//Drink 2
//Variable 3 : Drink 2 Water Amount ------- Array : [3][0]
//Variable 4 : Drink 2 Water Temperature -- Array : [4][0]
//Variable 5 : Drink 2 Powder Amount ----- Array : [5][0]
//Drink 3
//Variable 6 : Drink 3 Water Amount ------- Array : [6][0]
//Variable 7 : Drink 3 Water Temperature -- Array : [7][0]
//Variable 8 : Drink 3 Powder Amount ----- Array : [8][0]
//Time Related Variables
//Menu Setup
//Main Menu
LiquidLine start_line(0, 0, "Preparation");
LiquidLine main_line_1(0, 1, "Drink Settings");
LiquidLine main_line_2(0, 2, "Machine Settings");
LiquidScreen smain_1;
LiquidMenu mmain(lcd, smain_1);
//Preparation Menu
LiquidLine drink_1_start_line(0, 0, "Drink 1 Prep.");
LiquidLine drink_2_start_line(0, 1, "Drink 2 Prep.");
LiquidLine drink_3_start_line(0, 2, "Drink 3 Prep.");
LiquidLine mmback_line(0, 3, "Back");
LiquidScreen sstart_1;
LiquidMenu mstart(lcd, sstart_1);
//Drink Menu
LiquidLine sm_drink_1_line_1(0, 0, "Drink 1 Settings");
LiquidLine sm_drink_2_line_2(0, 1, "Drink 2 Settings");
LiquidLine sm_drink_3_line_3(0, 2, "Drink 3 Settings");
LiquidScreen sdrinks;
LiquidMenu mdrink(lcd, sdrinks);
//Drink 1 Menu
LiquidLine drink_1_line_1(0, 0, "Water Amnt. [ml]", variables[0][0]);
LiquidLine drink_1_line_2(0, 1, "Water Temp. [C]", variables[1][0]);
LiquidLine drink_1_line_3(0, 2, "Powder Amnt.[g]", variables[2][0]);
LiquidLine drink_1_line_4(0, 3, "Drink 1 Prep.");
LiquidLine drink_back_line(0, 3, "Back");
LiquidScreen sdrink_1;
LiquidMenu mdrink_1(lcd, sdrink_1);
//Drink 2 Menu
LiquidLine drink_2_line_1(0, 0, "Water Amnt. [ml]", variables[3][0]);
LiquidLine drink_2_line_2(0, 1, "Water Temp. [C]", variables[4][0]);
LiquidLine drink_2_line_3(0, 2, "Powder Amnt.[g]", variables[5][0]);
LiquidLine drink_2_line_4(0, 3, "Drink 2 Prep.");
LiquidScreen sdrink_2;
LiquidMenu mdrink_2(lcd, sdrink_2);
//Drink 3 Menu
LiquidLine drink_3_line_1(0, 0, "Water Amnt. [ml]", variables[6][0]);
LiquidLine drink_3_line_2(0, 1, "Water Temp. [C]", variables[7][0]);
LiquidLine drink_3_line_3(0, 2, "Powder Amnt. [g]", variables[8][0]);
LiquidLine drink_3_line_4(0, 3, "Drink 3 Prep.");
LiquidScreen sdrink_3;
LiquidMenu mdrink_3(lcd, sdrink_3);
//Machine Menu
LiquidLine tones_line_1(0, 0, "Tone Status ", tones_status_text);
LiquidLine machine_line_2(0, 1, "LED Status ", led_status_text);
LiquidLine machine_line_3(0, 2, "Test 3.3. ", variables[11][0]);
LiquidLine machine_line_4(0, 3, "Test 3.4. ", variables[12][0]);
LiquidLine machine_line_5(0, 4, "Test 3.5. ", variables[13][0]);
LiquidScreen smachine_1;
LiquidMenu mmachine(lcd, smachine_1);
//Overall Menu
LiquidSystem overall_menu;
//Functions
void count() {
Sensor.count();
void temperature_1() {
Serial.print("Internal Temp = ");
Serial.println(thermocouple_1.readInternal());
double c = thermocouple_1.readCelsius();
if (isnan(c)) {
Serial.println("Thermocouple 1 fault(s) detected!");
uint8_t e = thermocouple_1.readError();
if (e & MAX31855_FAULT_OPEN) Serial.println("FAULT: Thermocouple 1 is open - no connections.");
if (e & MAX31855_FAULT_SHORT_GND) Serial.println("FAULT: Thermocouple 1 is short-circuited to GND.");
if (e & MAX31855_FAULT_SHORT_VCC) Serial.println("FAULT: Thermocouple 1 is short-circuited to VCC.");
Serial.print("C = ");
Serial.println(c);
void temperature_2() {
Serial.println(thermocouple_2.readInternal());
double c = thermocouple_2.readCelsius();
if (isnan(c)) {
Serial.println("Thermocouple 2 fault(s) detected!");
uint8_t e = thermocouple_2.readError();
if (e & MAX31855_FAULT_OPEN) Serial.println("FAULT: Thermocouple 2 is open - no connections.");
if (e & MAX31855_FAULT_SHORT_GND) Serial.println("FAULT: Thermocouple 2 is short-circuited to GND.");
if (e & MAX31855_FAULT_SHORT_VCC) Serial.println("FAULT: Thermocouple 2 is short-circuited to VCC.");
Serial.println(c);
void onEb1Clicked(EncoderButton& eb) {
if (switching_focus == true) {
switching_focus = false;
Serial.println("switching_focus = false");
overall_menu.call_function(3);
overall_menu.update();
makeSomeNoise();
Serial.println("switching_focus = true");
void onEb1Encoder(EncoderButton& eb) {
int encoderValue = eb.increment();
if (encoderValue > 0 && switching_focus == true) {
overall_menu.switch_focus(true);
Serial.println("Focus down");
eb1_update_executed = true;
makeSomeNoise();
} else if (encoderValue < 0 && switching_focus == true) {
overall_menu.switch_focus(false);
Serial.println("Focus up");
makeSomeNoise();
} else if (encoderValue > 0 && switching_focus == false) {
overall_menu.call_function(increase);
Serial.println("Value Increased");
makeSomeNoise();
} else if (encoderValue < 0 && switching_focus == false) {
overall_menu.call_function(decrease);
Serial.println("Value decreased");
makeSomeNoise();
void makeSomeNoise() {
if (variables[9][0] == 1) {
tone(speakerPin, tones[3]);
delay(tones_duration);
noTone(speakerPin);
// Increase a variable's value
void increase_variable(int variable_index) {
if (variables[variable_index][0] < variables[variable_index][1]) {
variables[variable_index][0] += variables[variable_index][3];
Serial.print("Increase ");
Serial.print(variable_index);
Serial.print(" called");
//Save Input
EEPROM.put(variables[variable_index][4], variables[variable_index][0]);
Serial.print(" saved: ");
Serial.print(variables[variable_index][0]);
Serial.print(" in EEPROM postion ");
Serial.println(variables[variable_index][4]);
variables[variable_index][0] = variables[variable_index][1];
Serial.print("Max ");
Serial.print(" reached");
// Decrease a variable's value
void decrease_variable(int variable_index) {
if (variables[variable_index][0] > variables[variable_index][2]) {
variables[variable_index][0] -= variables[variable_index][3];
Serial.print("Decrease ");
//Save Input
variables[variable_index][0] = variables[variable_index][2];
Serial.print("Min ");
//Increase / Decrease Functions
void increase_variable_0() {
increase_variable(0);
void decrease_variable_0() {
decrease_variable(0);
void increase_variable_1() {
increase_variable(1);
void decrease_variable_1() {
decrease_variable(1);
void increase_variable_2() {
increase_variable(2);
void decrease_variable_2() {
decrease_variable(2);
void increase_variable_3() {
increase_variable(3);
void decrease_variable_3() {
decrease_variable(3);
void increase_variable_4() {
increase_variable(4);
void decrease_variable_4() {
decrease_variable(4);
void increase_variable_5() {
increase_variable(5);
void decrease_variable_5() {
decrease_variable(5);
void increase_variable_6() {
increase_variable(6);
void decrease_variable_6() {
decrease_variable(6);
void increase_variable_7() {
increase_variable(7);
void decrease_variable_7() {
decrease_variable(7);
void increase_variable_8() {
increase_variable(8);
void decrease_variable_8() {
decrease_variable(8);
void increase_variable_11() {
increase_variable(11);
void decrease_variable_11() {
decrease_variable(11);
void increase_variable_12() {
increase_variable(12);
void decrease_variable_12() {
decrease_variable(12);
void increase_variable_13() {
increase_variable(13);
void decrease_variable_13() {
decrease_variable(13);
//Change tones_status
void increase_tones_status() {
if (variables[9][0] == 0) {
variables[9][0] = 1;
Serial.print("Tone switched ON");
strncpy(tones_status_text, tones_on, sizeof(tones_on));
//Save Input
EEPROM.put(variables[9][4], variables[9][0]);
Serial.print("tones_status saved ");
Serial.print(variables[9][0]);
variables[9][0] = variables[9][1];
Serial.println("Max Tone Value reached");
void decrease_tones_status() {
variables[9][0] = 0;
Serial.print("Tone switched OFF");
strncpy(tones_status_text, tones_off, sizeof(tones_off));
variables[9][0] = variables[9][2];
Serial.println("Min Tone Value reached");
//Change Led_status
void increase_led_status() {
if (variables[10][0] == 0) {
variables[10][0] = 1;
Serial.print("LED switched ON");
strncpy(led_status_text, led_on, sizeof(led_on));
//Save Input
EEPROM.put(variables[10][4], variables[10][0]);
Serial.print("LED_status saved ");
Serial.print(variables[10][0]);
variables[10][0] = variables[10][1];
Serial.println("Max LED Status reached");
void decrease_led_status() {
if (variables[10][0] == 1) {
variables[10][0] = 0;
Serial.print("LED switched OFF");
strncpy(led_status_text, led_off, sizeof(led_off));
variables[10][0] = variables[10][2];
Serial.println("Min LED Status reached");
//Change LED Power
void LEDPower() {
analogWrite(ledPin, 0); //This Values have been changed to make the LED work according to the value in the Menu
analogWrite(ledPin, 255); //This Values have been changed to make the LED work according to the value in the Menu
//Fade LED
void fadeLED() {
if (switching_focus == false) {
ledtime = ledtime + 50;
ledvalue = 128 + 127.5 * sin(2 * PI / ledperiode * ledtime);
analogWrite(ledPin, ledvalue);
bool ledMessage = false;
while (ledvalue != 255) {
if (!ledMessage) {
Serial.println("fadeLED closed");
ledMessage = true;
//Drink 1 Starting Function
void drink_1_start_function() {
//Serial.println("Drink_1_start_function called");
while (variables[0][5] < variables[0][0] || variables[2][5] > (-1) * variables[2][0]) {
//Serial.println("Drink_1_start_function WHILE function called");
Drink_1_Water_Dispensing();
Drink_1_Powder_Dispensing();
Drink_1_Update_LCD(); //Updated according to the variables in this sketch
void Drink_1_Update_LCD() {
//Serial.println("Drink_1_Update_LCD called");
if (millis() - windowStartTime_LCD > WindowSize_LCD) { //time to update the LCD Screen
if (variables[0][5] < variables[0][0] || variables[2][5] > (-1) * variables[2][0]) { //if the current water amount is smaller than the actual or the current weight is smaller than the desired weight
lbg0.drawValue(variables[0][5], variables[0][0]);
// Volume Display
if (variables[0][5] < 10) {
lcd.print(variables[0][5]);
if (variables[0][5] >= 10 && variables[0][5] < 100) {
if (variables[0][5] >= 100) {
// Powder Display
if (variables[2][5] * (-1) < 10) {
lcd.print(variables[2][5] * (-1));
if (variables[2][5] * (-1) >= 10 && variables[2][5] * (-1) < 100) {
if (variables[2][5] * (-1) >= 100) {
if (TX < 10) {
lcd.print(TX, 0);
lcd.print(TX, 0);
if (TX >= 100) {
lcd.print(TX, 0);
lcd.clear();
lcd.print("DONE");
void Drink_1_Water_Dispensing() {
//Serial.println("Drink_1_Water_Dispensing called");
Setpoint_1 = variables[1][0];
if (variables[0][5] < variables[0][0]) {
Sensor.read();
variables[0][5] = Sensor.getVolume() * 1000;
Serial.print(variables[0][5]);
//Temperature NTC
VR = VCC - VRT;
ln = log(RT / RT0);
Serial.print(TX);
//Thermocouple
Serial.print(d);
Input_1 = TX;
myPID_1.Compute();
Serial.println("");
Serial.print(Setpoint_1);
Serial.print(Output_1);
if (Output_1 > millis() - windowStartTime) {
void Drink_1_Powder_Dispensing() {
//Serial.println("Drink_1_Powder_Dispensing called");
Serial.println("");
temp_variables_2_5 = (scale_1.get_units(1) + scale_2.get_units(1) + scale_3.get_units(1) + scale_4.get_units(1));
variables[2][5] = int(temp_variables_2_5);
Serial.print(variables[2][5]);
Serial.println(" [g]");
if (variables[2][5] > (-1) * variables[2][0] && Powder_Status == LOW) {
//Drink 2 Starting Function
void drink_2_start_function() {
//replace with the Drink 1 Starting function and adjust once done
Serial.print("Drink 2 Start selected");
lcd.clear();
LcdBarGraph lbg0(&lcd, 16, 0, 1);
byte i0 = 0;
for (byte i0 = 0; i0 < 250; i0++) {
fadeLED();
lcd.setCursor(4, 0);
lcd.print("Drink 2 Prep.");
lbg0.drawValue(i0, 250);
delay(10);
//Drink 3 Starting Function
void drink_3_start_function() {
Serial.print("Drink 3 Start selected");
lcd.clear();
byte i0 = 0;
fadeLED();
lcd.print("Drink 3 Prep.");
delay(10);
//Function to switch to the Preparation Menu
void goto_mstart() {
overall_menu.change_menu(mstart);
Serial.println("Go To Preparation Menu");
mstart.set_focusedLine(0);
//Function to switch to the Drink Menu
void goto_mdrink() {
overall_menu.change_menu(mdrink);
Serial.println("Go To Drinks Menu");
mdrink.set_focusedLine(0);
//Function to switch to the Drink_1 Menu
void goto_sdrink_1() {
overall_menu.change_menu(mdrink_1);
Serial.println("Go To Drinks 1 Menu");
mdrink_1.set_focusedLine(0);
//Function to switch to the Drink_2 Menu
void goto_sdrink_2() {
overall_menu.change_menu(mdrink_2);
Serial.println("Go To Drinks 2 Menu");
mdrink_2.set_focusedLine(0);
//Function to switch to the Drink_3 Menu
void goto_sdrink_3() {
overall_menu.change_menu(mdrink_3);
Serial.println("Go To Drinks 3 Menu");
mdrink_3.set_focusedLine(0);
//Function to switch to the Machine Menu
void goto_mmachine() {
overall_menu.change_menu(mmachine);
Serial.println("Go To Machine Menu");
mmachine.set_focusedLine(0);
//Callback function that will be attached to back_line to Main Menu
void mm_go_back() {
overall_menu.change_menu(mmain);
Serial.println("Go To Main Menu");
//Callback functiont that brings you back to the Drings Settings Menu
void drink_go_back() {
//Setpoint = 70; //Temperature is the Setpoint
myPID_1.SetOutputLimits(0, WindowSize);
myPID_1.SetSampleTime(WindowSize / 10); // make sure we measure and sample at least 10 times per WindowSize.
myPID_1.SetMode(AUTOMATIC);
//Thermocouple
//Scales
//Flowmeter
//Pump
//Print all Sensor Values and test all actuators in the Serial Monitor
Serial.println("Sensor Values on Start up:");
//Print Temperatures
Serial.print("Temperatures: ");
//Thermocouple 1
Serial.print("TC Internal Temp. 1 = ");
Serial.print(thermocouple_1.readInternal());
Serial.print("[C] --- ");
Serial.print(c);
//Thermocouple 2
Serial.print("TC Internal Temp. 2 = ");
Serial.print(thermocouple_2.readInternal());
Serial.print("Water Outlet Control Temp. = ");
Serial.print(d);
//NTC in FTH
T0 = 25 + 273.15;
VR = VCC - VRT;
ln = log(RT / RT0);
Serial.print("NTC : ");
Serial.print(TX);
Serial.println(" [C]");
//Scales
Serial.print("Scales : ");
Serial.print("Scale 1: ");
Serial.print(scale_1.get_units(), 1);
Serial.print("[g]");
Serial.print(" --- Scale 2: ");
Serial.print(scale_2.get_units(), 1);
Serial.print(" --- Scale 3: ");
Serial.print(scale_3.get_units(), 1);
Serial.print(" --- Scale 4: ");
Serial.print(scale_4.get_units(), 1);
Serial.println("[g]");
//Relays
Serial.print("Pump, Motor, FTH Test:");
Serial.print(" Pump ON --- ");
Serial.print("Motor ON --- ");
digitalWrite(RELAY_PIN, HIGH);
Serial.print("FTH ON --- ");
delay(100);
Serial.print("Pump OFF --- ");
Serial.print("Motor OFF ---");
digitalWrite(RELAY_PIN, LOW);
Serial.println("FTH OFF");
//Flow Sensor
Serial.print("Flow Sensor Test: ");
Sensor.read();
int actual_volume = Sensor.getVolume() * 1000;
Serial.print(actual_volume);
Serial.println(" [ml]");
//Start Power LED
//LEDPower();
//Link the encoder event(s) to your function
eb1.setClickHandler(onEb1Clicked);
eb1.setEncoderHandler(onEb1Encoder);
//Set Focus Symbol
mmain.set_focusSymbol(Position::CUSTOM, 0);
//Set Focus for each line
start_line.set_focusPosition(Position::CUSTOM, 19, 0);
drink_1_start_line.set_focusPosition(Position::CUSTOM, 19, 0);
drink_2_start_line.set_focusPosition(Position::CUSTOM, 19, 1);
drink_3_start_line.set_focusPosition(Position::CUSTOM, 19, 2);
main_line_1.set_focusPosition(Position::CUSTOM, 19, 1);
main_line_2.set_focusPosition(Position::CUSTOM, 19, 2);
mmback_line.set_focusPosition(Position::CUSTOM, 19, 3);
drink_back_line.set_focusPosition(Position::CUSTOM, 19, 3);
tones_line_1.set_focusPosition(Position::CUSTOM, 19, 0);
machine_line_2.set_focusPosition(Position::CUSTOM, 19, 1);
machine_line_3.set_focusPosition(Position::CUSTOM, 19, 2);
machine_line_4.set_focusPosition(Position::CUSTOM, 19, 3);
machine_line_5.set_focusPosition(Position::CUSTOM, 19, 3);
sm_drink_1_line_1.set_focusPosition(Position::CUSTOM, 19, 0);
sm_drink_2_line_2.set_focusPosition(Position::CUSTOM, 19, 1);
sm_drink_3_line_3.set_focusPosition(Position::CUSTOM, 19, 2);
drink_1_line_2.set_focusPosition(Position::CUSTOM, 19, 1);
drink_1_line_3.set_focusPosition(Position::CUSTOM, 19, 2);
drink_1_line_4.set_focusPosition(Position::CUSTOM, 19, 3);
drink_2_line_1.set_focusPosition(Position::CUSTOM, 19, 0);
drink_2_line_3.set_focusPosition(Position::CUSTOM, 19, 2);
drink_2_line_4.set_focusPosition(Position::CUSTOM, 19, 3);
drink_3_line_1.set_focusPosition(Position::CUSTOM, 19, 0);
drink_3_line_2.set_focusPosition(Position::CUSTOM, 19, 1);
drink_3_line_4.set_focusPosition(Position::CUSTOM, 19, 3);
//Read the values recorded in the EEPROM
for (int j = 0; j < 15; j++) {
EEPROM.get(variables[j][4], variables[j][0]);
Serial.print("The EEPDROM value for ");
Serial.print(j);
Serial.print(" is ");
Serial.println(variables[j][0]);
if (variables[9][0] == true) {
if (variables[10][0] == true) {
//Start LCD Screen
lcd.begin(LCD_Columns, LCD_Rows);
lcd.setCursor(12, 3);
lcd.print("V.T.1.4.");
delay(2000);
lcd.clear();
//Attach lines to the main menu
smain_1.add_line(start_line);
smain_1.add_line(main_line_1);
smain_1.add_line(main_line_2);
//Attach lines to the preparation menu
sstart_1.add_line(drink_1_start_line);
sstart_1.add_line(drink_2_start_line);
sstart_1.add_line(drink_3_start_line);
sstart_1.add_line(mmback_line);
//Attach lines to the drinks menu
sdrinks.add_line(sm_drink_1_line_1);
sdrinks.add_line(sm_drink_2_line_2);
sdrinks.add_line(sm_drink_3_line_3);
sdrinks.add_line(mmback_line);
//Attach lines to the drink 1 menu
sdrink_1.add_line(drink_1_line_1);
sdrink_1.add_line(drink_1_line_2);
sdrink_1.add_line(drink_1_line_3);
sdrink_1.add_line(drink_1_line_4); //might need to be a different drink_1 start line
sdrink_1.add_line(drink_back_line);
//Attach lines to the drink 2 menu
sdrink_2.add_line(drink_2_line_1);
sdrink_2.add_line(drink_2_line_2);
sdrink_2.add_line(drink_2_line_3);
sdrink_2.add_line(drink_2_line_4); //might need to be a different drink_2 start line
sdrink_2.add_line(drink_back_line);
//Attach lines to the drink 3 menu
sdrink_3.add_line(drink_3_line_1);
sdrink_3.add_line(drink_3_line_2);
sdrink_3.add_line(drink_3_line_3);
sdrink_3.add_line(drink_3_line_4); //might need to be a different drink_3 start line
sdrink_3.add_line(drink_back_line);
//Attach lines to the machine meu
smachine_1.add_line(tones_line_1);
smachine_1.add_line(machine_line_2);
smachine_1.add_line(machine_line_3);
smachine_1.add_line(machine_line_4);
smachine_1.add_line(machine_line_5);
smachine_1.add_line(mmback_line);
//Attaching a function to the lines is required for scrolling to work
//Main
start_line.attach_function(3, goto_mstart);
main_line_1.attach_function(3, goto_mdrink);
main_line_2.attach_function(3, goto_mmachine);
mmback_line.attach_function(3, mm_go_back);
//Preparation
drink_1_start_line.attach_function(3, drink_1_start_function);
drink_2_start_line.attach_function(3, drink_2_start_function);
drink_3_start_line.attach_function(3, drink_3_start_function);
//Drink
sm_drink_1_line_1.attach_function(3, goto_sdrink_1);
sm_drink_2_line_2.attach_function(3, goto_sdrink_2);
sm_drink_3_line_3.attach_function(3, goto_sdrink_3);
//Drink 1
drink_1_line_1.attach_function(increase, increase_variable_0);
drink_1_line_1.attach_function(decrease, decrease_variable_0);
drink_1_line_2.attach_function(increase, increase_variable_1);
drink_1_line_2.attach_function(decrease, decrease_variable_1);
drink_1_line_3.attach_function(increase, increase_variable_2);
drink_1_line_3.attach_function(decrease, decrease_variable_2);
drink_1_line_4.attach_function(3, drink_1_start_function);
drink_back_line.attach_function(3, drink_go_back);
//Drink 2
drink_2_line_1.attach_function(increase, increase_variable_3);
drink_2_line_1.attach_function(decrease, decrease_variable_3);
drink_2_line_2.attach_function(increase, increase_variable_4);
drink_2_line_2.attach_function(decrease, decrease_variable_4);
drink_2_line_3.attach_function(increase, increase_variable_5);
drink_2_line_3.attach_function(decrease, decrease_variable_5);
drink_2_line_4.attach_function(3, drink_2_start_function);
//Drink 3
drink_3_line_1.attach_function(increase, increase_variable_6);
drink_3_line_1.attach_function(decrease, decrease_variable_6);
drink_3_line_2.attach_function(increase, increase_variable_7);
drink_3_line_2.attach_function(decrease, decrease_variable_7);
drink_3_line_3.attach_function(increase, increase_variable_8);
drink_3_line_3.attach_function(decrease, decrease_variable_8);
drink_3_line_4.attach_function(3, drink_3_start_function);
//Machine
tones_line_1.attach_function(increase, increase_tones_status);
tones_line_1.attach_function(decrease, decrease_tones_status);
machine_line_2.attach_function(increase, increase_led_status);
machine_line_2.attach_function(decrease, decrease_led_status);
machine_line_3.attach_function(increase, increase_variable_11);
machine_line_3.attach_function(decrease, decrease_variable_11);
machine_line_4.attach_function(increase, increase_variable_12);
machine_line_4.attach_function(decrease, decrease_variable_12);
machine_line_5.attach_function(increase, increase_variable_13);
machine_line_5.attach_function(decrease, decrease_variable_13);
// Set the number of lines the display has in the certain Menu
smain_1.set_displayLineCount(LCD_Rows);
sstart_1.set_displayLineCount(LCD_Rows);
sdrinks.set_displayLineCount(LCD_Rows);
sdrink_1.set_displayLineCount(LCD_Rows);
sdrink_2.set_displayLineCount(LCD_Rows);
sdrink_3.set_displayLineCount(LCD_Rows);
smachine_1.set_displayLineCount(LCD_Rows);
mmain.add_screen(smain_1);
mstart.add_screen(sstart_1);
mdrink.add_screen(sdrinks);
mdrink_1.add_screen(sdrink_1);
mdrink_2.add_screen(sdrink_2);
mdrink_3.add_screen(sdrink_3);
mmachine.add_screen(smachine_1);
overall_menu.add_menu(mmain);
overall_menu.add_menu(mstart);
overall_menu.add_menu(mdrink);
overall_menu.add_menu(mdrink_1);
overall_menu.add_menu(mdrink_2);
overall_menu.add_menu(mdrink_3);
overall_menu.add_menu(mmachine);
overall_menu.set_focusedLine(0);
//Power Indicator LED
LEDPower();
fadeLED();
eb1.update();
//digitalWrite(DC_Motor, HIGH);
if (eb1_update_executed) {
delay(50);
