Hello, I’m having a problem with an output number 4. When message is received it should turn on the relay but nothing happens. I know it should be an issue in the code, because I’m kinda new in Arduino programming language. Thank you for your help.
P.S. I’m using Arduino Mega 2560 and and this GSM shield.
#include "SIM900.h"
#include <SoftwareSerial.h>
//If not used, is better to exclude the HTTP library,
//for RAM saving.
//If your sketch reboots itself proprably you have finished,
//your memory available.
//#include "inetGSM.h"
//If you want to use the Arduino functions to manage SMS, uncomment the lines below.
#include "sms.h"
SMSGSM sms;
//To change pins for Software Serial, use the two lines in GSM.cpp.
//GSM Shield for Arduino
//www.open-electronics.org
//this code is based on the example of Arduino Labs.
//Simple sketch to send and receive SMS.
int numdata;
int relay_a=4;
boolean started=false;
char smsbuffer[160];
char n[20];
//debug begin
char sms_position;
char phone_number[20]; // array for the phone number string
char sms_text[100];
int i;
//debug end
//Serial connection.
Serial.println("GSM Shield testing.");
//Start configuration of shield with baudrate.
//For http uses is raccomanded to use 4800 or slower.
if (gsm.begin(4800))
Serial.println("\nstatus=READY");
started=true;
Serial.println("\nstatus=IDLE");
if(started)
//Enable this two lines if you want to send an SMS.
//if (sms.SendSMS("3471234567", "Arduino SMS"))
//Serial.println("\nSMS sent OK");
//if NO SPACE ,you need delte SMS from position 1 to position 20
//please enable this four lines
//for(i=1;i<=20;i++)
//sms.DeleteSMS(i);
// Initialize PINs
pinMode( 4, OUTPUT );
digitalWrite( 4, LOW );
if(started)
//Read if there are messages on SIM card and print them.
sms_position=sms.IsSMSPresent(SMS_UNREAD);
if (sms_position)
digitalWrite (relay_a, HIGH);
// read new SMS
Serial.print("SMS postion:");
Serial.println(sms_position,DEC);
sms.GetSMS(sms_position, phone_number, sms_text, 100);
// now we have phone number string in phone_num
Serial.println(phone_number);
// and SMS text in sms_text
Serial.println(sms_text);
Serial.println("NO NEW SMS,WAITTING");
