relay overkill
Hi, I am working on a little project and need some advice.
I am using an arduino (probably a regular one, but possibly the fio) and the plan was to use a relay to close a circuit on another piece of electronics. The electronics are 12v, and obviously its important to keep the 2 circuits separated. The circuit in the electronic has little or no load. It's very similar to the button sketch for arduino, except 12 volts.
Originally I was going to use a relay, but as I started to lay out the schematics I realized it was over kill. What do you suggest in its place?
Darlington, opto, something else?
Thanks,
Jim
Why?
If you have to keep them totally separate use an opto isolator.
However if you can have the grounds common then you can use a transistor or a FET.
Ok, Opto-Isolater it is.
The arduino part of the project must be portable and separate from the main piece of electronics, that I own and stays with me. The main piece of electronics is rented from various venders and is quite expensive, it has a port that my project connects to. So yeah I want to keep them separated.
Thanks Grumpy Mike.
Jim
If the rental device shows that you just need a switch (with no pull-up resistors or anything like that), then a relay is probably best because a relay is just an electrically activated switch. You may not need the isolation, but you would like to replicate a switch.
The fact that it’s an expensive rental is not an indication that you need ground isolation. i.e. If you rent a P.A. system, you can plug-in your own microphone and there is no isolation.
And no matter what you do, there is still a hard-connection between your circuit and the rented equipment… If you use an opto or a relay, one side of the opto/relay is still connected to their equipment.
