Hi Arduino community,
Very new to Arduino and programming in general. This is one of my first micro controller projects and any help or advice would be greatly appreciated.
Working on a project using a Mega 2560, Adafruit MPR121 touch sensor and the Sparkfun wav trigger to make a 12 note polyphonic touch keyboard. Now just need to add the same “poly function” to 12 relays, so that when one of the keys is touched it plays a note and turns on a light. The key functionality would be that multiple lights and notes can be activated simultaneously. Is there a board out there that does what the WAV trigger does, but instead of triggering a wav file it triggers a relay and can trigger multiple relays simultaneously?
So far have been able to get the code to trigger the relays, but every key just triggers the same relay…
#include <Wire.h>
#include "Adafruit_MPR121.h"
Adafruit_MPR121 cap = Adafruit_MPR121();
uint16_t lasttouched = 0;
uint16_t currtouched = 0;
int pins[] = {52,53};
pinMode(52, OUTPUT);
pinMode(53, OUTPUT);
if (!cap.begin(0x5A)) {
while (1);
currtouched = cap.touched();
for (uint8_t i=0; i<12; i++) {
if ((currtouched & _BV(i)) && !(lasttouched & _BV(i)) ) {
digitalWrite(52, LOW);
if (!(currtouched & _BV(i)) && (lasttouched & _BV(i)) ) {
digitalWrite(52, HIGH);
lasttouched = currtouched;
