Relay Power Arduino
I made a timed Arduino that turns on and off a relay. Rather then plugging two cords into the wall, is there a way I could tap into the power coming through the relay?
I recently built a lamp timer that turns two lamps on at sunset, and off at 11:00PM. (I got a lot of help from Jack Christensen, who gave me his code for a similar project)
What I did was get a double-wide outlet box, which holds everything. I have one cord coming into it from the wall, but inside, the power is split, where it goes to a small USB wall wart I got from monoprice.com that powers the Arduino (it's a micro), and to the outlets via two relays.
tylerv:
If you intend to regulate the mains grid voltage, then you can go some ways using triacs etc, but the best and safe way (imo) is use a transformer…
Can you explain in depth what is your goal ?
A transformer sounds like my thing. So when I have my timer, I have two power cords. One coming from the wall, to the relay. The other coming from the wall, to power the Arduino. Is there a way to get both of these devices running off the main grid?
