relay problem
i have questions I use ct sensor and relays. ct sensor to measure the current output of the lamp is given (turn off:0A turn on : 0.89, 0.90, 0.91) and when I use relay to control is given (turn off:0.07 turn on:between 0.3 and 0.9 and etc.)
what's problem? thank you in advance
Maybe you are only measuring current to the relay. How is everything wired? Draw a diagram or take pictures.
