Relay Shield Code Issues
My project is a Jeopardy style table that has 4 switches. When one switch is pressed, it lights up its corresponding light and disables the other switches for 5 seconds, after which it returns back to a waiting state. Here is the code:
//Pressing 1 switch blocks the others and lights up a light through a relay for 5 seconds
//4 switches and 4 corresponding relays
// These are constant because it makes the code run faster on the microcontroller.  The compiler more or less does this.
const byte switchA = 2;
const byte switchB = 3;
const byte switchC = 4;
const byte switchD = 5;
const byte relayA = 6;
const byte relayB = 7;
const byte relayC = 8;
const byte relayD = 9;
// enumerated states so that things don't die immediately...
enum state_t { A = 1, B = 2, C = 3, D = 4, Wait = 5 };
void setup(){
  pinMode (switchA, INPUT_PULLUP);
  pinMode (switchB, INPUT_PULLUP);
  pinMode (switchC, INPUT_PULLUP);
  pinMode (switchD, INPUT_PULLUP);
  pinMode (relayA, OUTPUT);
  pinMode (relayB, OUTPUT);
  pinMode (relayC, OUTPUT);
  pinMode (relayD, OUTPUT);
  static state_t state = Wait;
  // Variables with static are initialized the first time a function runs.
  // These are non-global so that CS professors won't complain.
  switch(state) {
    case A:
      digitalWrite(relayA,HIGH);
      digitalWrite(relayB,LOW);
      digitalWrite(relayC,LOW);
      digitalWrite(relayD,LOW);
      delay(5000);
      digitalWrite(relayA,LOW);
      state = Wait;
    case B:
      digitalWrite(relayB,HIGH);
      delay(5000);
      state = Wait;
    case C:
      digitalWrite(relayC,HIGH);
      delay(5000);
      state = Wait;
    case D:
      digitalWrite(relayD,HIGH);
      delay(5000);
      state = Wait;
    case Wait:
      if (!digitalRead(switchA)) {
        state = A;
      } else if (!digitalRead(switchB)) {
	state = B;
      } else if (!digitalRead(switchC)) {
	state = C;
      } else if (!digitalRead(switchD)) {
	state = D;
	state = Wait;
    default:
      state = Wait;
My friend helped me program it as a FSM but when I tested it the relay for case A immediately activated when power was applied. It may be a hardware issue but can anybody see any issues with the programming itself? Thank you.
The code looks OK.
My guess is that the Switch A pin is shorted to ground.
If you hold down B does the relay for B trigger after A has been on for five seconds? That would help prove that the rest of the hardware was working as expected.
I'm not sure yet. I only just plugged it in to power and heard the click and tested relayA. I'll go test the other ones and report back.
