Has anyone used the relay shield modules for Arduino?
Are the relays noisy/ make clicking sounds, and can you stack two modules to control 8 relays?
THANKS!!
Steve
THANKS!!
Steve
You could start providing a link to the product.
Good Point!
Here is the link: https://www.amazon.com/dp/B01K18QFRC/_encoding=UTF8?coliid=I2U8OA7K6JS37W&colid=3U2CEPEPWF1LA&psc=0
No experience with them. I found the schematic on this site
It uses 4 fixed pins to control the relays; this implies that you will have to hack it if you want to stack two on top of the Arduino.
2)
It uses the 5V of the Arduino; when a relay is activated, it will initially draw quite a bit of current and the Arduino might reset. Therefore I would not buy it (although the relays might be low power types and the problem might not be as big as I have presented it].
