I'm new to electronics and have wired up a relay (shinmei rsb-12-s) as part of an experiment.
See my breadboard wiring below. The circuit is being fed 12v (1 amp) and when powered, the yellow LED lights up.
I'm expecting the yellow LED to go out and the red LED to light up when I press the pushbutton.
Instead just the yellow LED goes out - nothing goes with the red one. I've checked that both LEDs are in the right way and that both work. - If I swap the LEDs over (leaving the legs in the same orientation) I just get a red LED that goes out when I press the button.
The relay is switching OK (or seems to be). I've got an identical relay which I've opened up and repeated the test while testing the contacts inside and when pressing the pushbutton the contact leading to the red LED receives the power.
Can someone tell me why the red LED remains unlit, even though it seems to be receiving power please (honestly, it's in the right way).
Cheers in advance
