Relay Starts with Arduino!
Hi
I face a problem with my projects if using relays.
Always when I start operating the Arduino the relay is on at the same time for a second almost and I don’t know why although there is no instruction for that. Here is my code for an egg incubator.
#include "dht.h"
#define dht_apin A0 // Analog Pin sensor is connected to A0
int heater = 5; //Pin 5 is connected to heater through Relay
dht DHT; //Calling the library for the dht sensor
void setup(){
 pinMode(dht_apin,INPUT);    //Analog pin is input
 pinMode(heater,OUTPUT); //Digital pin is output
 Serial.begin(9600); //Starting serial communication
void loop(){
//Reading the temperature from the sensor
   DHT.read11(dht_apin);
   int temp = DHT.temperature;
   Serial.print("temperature = ");
   Serial.print(temp);
   Serial.println("C  ");
   delay(5000);//Wait 5 seconds before accessing sensor again.
if (temp < 37){ //Switch ON heater if temperature is low
 digitalWrite(heater,LOW);
else{digitalWrite(heater,HIGH);} //Switch off heater if it is hot enough
  delay(100);
set the pin low (read throughly the doc) https://www.arduino.cc/en/Tutorial/DigitalPins
put some delay as well at the very beginning...,
I assume you are connecting correctly the Relay...
Please edit you post to have code tags.
Also, devil is in de details. I bed you don't just use a relay but a relay module, don't you? If so, be sure to set it to the OFF state when you make the pin an output. Aka
digitalWrite(heater, HIGH);
