Relay Suggestion
I need to use a relay to cut the power on and off to a motor. The relay should be able to take 120vdc and 12 amps. Does anyone know of a relay that will work? I've been looking all over the Internet and cannot find one. Thanks in advance!
You should try the real distributors, like Digikey & Mouser: http://www.digikey.com/products/en/relays/power-relays-over-2-amps/188?k=relay&k=&pkeyword=relay&pv1411=38&FV=fff40010%2Cfff80367%2Cffe000bc%2C16080004&mnonly=0&newproducts=0&ColumnSort=0&page=1&stock=1&quantity=0&ptm=0&fid=0&pageSize=25
What is the coil voltage that I see on the relay you suggested? I'm used to the basic sainsmart relays like this one which obviously won't work but it would be nice to have something similar. http://www.ebay.com/itm/like/381279786743?lpid=82&chn=ps&ul_noapp=true
Hi, See this one: 240V and 30A
DISCLAIMER: Mentioned stuff from my own shop...
OMRON G7L-2A-BUBJ-C8 24vdc coil contacts 25amp 240volt
Hi, How often will you be switching the motor on and off?
Tom... :)
terryking228:
DISCLAIMER: Mentioned stuff from my own shop…
This is essentially what I need but I need one for DC. Have you got a recommendation there?
