Hello there!
I kindly request help for my esp32 project
The idea is as follows: An esp32 reads out two temperature sensors and controlls a relay switch.
These functionalities are visualized on a web server. The temperature part works fine.
For the relay, the web server has a slider switch, from where the relay can be controlled. Further, there is a timer implemented, so that after 4 hours, the relay switches off. The code works properly with a little error:
When the relay switches to state off, the slider on the webserver gets not updated and still shows state on.
My question: what do I need to change that the slider turns off automatically?
Btw:
I copied code from differnt sources, since I am not very skilled in the html language and programming web-servers. So forgive me, if the code looks a bit messy
Here is the code:
Rui Santos
Complete project details at https://RandomNerdTutorials.com
// Import required libraries
#ifdef ESP32
#include <WiFi.h>
#include <ESPAsyncWebServer.h>
#else
#include <Arduino.h>
#include <ESP8266WiFi.h>
#include <Hash.h>
#include <ESPAsyncTCP.h>
#endif
#include <OneWire.h>
#include <DallasTemperature.h>
// Number of temperature devices found
int numberOfDevices;
// We'll use this variable to store a found device address
DeviceAddress tempDeviceAddress;
// Data wire is connected to GPIO 4
#define ONE_WIRE_BUS 4
// Setup a oneWire instance to communicate with any OneWire devices
OneWire oneWire(ONE_WIRE_BUS);
// Pass our oneWire reference to Dallas Temperature sensor
DallasTemperature sensors(&oneWire);
// variables
//Temperature variables
// Variables to store temperature values
String temperatureF = "";
String temperatureC = "";
// Timer variables
unsigned long lastTime = 0;
unsigned long timerDelay = 1000; // was 30000 before
// Replace with your network credentials
const char* ssid = "...";
const char* password = "...";
//Relay variables
// Set to true to define Relay as Normally Open (NO)
#define RELAY_NO false
// Set number of relays
#define NUM_RELAYS 1
// Assign each GPIO to a relay
int relayGPIOs[NUM_RELAYS] = {5};
const char* PARAM_INPUT_1 = "relay";
const char* PARAM_INPUT_2 = "state";
// Store the relay state and the time it was turned on
//bool relayState_chat = false;
unsigned long relayStartTime = 0;
// Create AsyncWebServer object on port 80
AsyncWebServer server(80);
// functions
String readDSTemperatureC() {
// Call sensors.requestTemperatures() to issue a global temperature and Requests to all devices on the bus
sensors.requestTemperatures();
float tempC = sensors.getTempCByIndex(0)+1;
if(tempC == -127.00) {
Serial.println("Failed to read from DS18B20 sensor");
return "--";
Serial.print("Temperature Celsius: ");
Serial.println(tempC);
return String(tempC);
String readDSTemperatureF() {
float tempF = sensors.getTempCByIndex(1)+1;
if(int(tempF) == -196){
return "--";
Serial.print("Temperature Fahrenheit: ");
Serial.println(tempF);
return String(tempF);
//Relay relayState()-function
String relayState(int numRelay){
if(RELAY_NO){
if(digitalRead(relayGPIOs[numRelay-1])){
return "";
else {
return "checked";
else {
return "checked";
else {
return "";
return "";
// Relay state function chat
bool getRelayState() {
int status_relay = digitalRead(relayGPIOs[0]);
//return relayState_chat ? "checked" : "";
if (status_relay == HIGH){
return true;
else {
return false;
// build web server
const char index_html[] PROGMEM = R"rawliteral(
<!DOCTYPE HTML><html>
<head>
<meta name="viewport" content="width=device-width, initial-scale=1">
<style>
html {font-family: Arial; display: inline-block; text-align: center;}
h2 {font-size: 3.0rem;}
p {font-size: 3.0rem;}
body {max-width: 600px; margin:0px auto; padding-bottom: 25px;}
.switch {position: relative; display: inline-block; width: 120px; height: 68px}
.switch input {display: none}
.slider {position: absolute; top: 0; left: 0; right: 0; bottom: 0; background-color: #ccc; border-radius: 34px}
.slider:before {position: absolute; content: ""; height: 52px; width: 52px; left: 8px; bottom: 8px; background-color: #fff; -webkit-transition: .4s; transition: .4s; border-radius: 68px}
input:checked+.slider {background-color: #2196F3}
input:checked+.slider:before {-webkit-transform: translateX(52px); -ms-transform: translateX(52px); transform: translateX(52px)}
</style>
</head>
<head>
<link rel="stylesheet" href="https://use.fontawesome.com/releases/v5.7.2/css/all.css" integrity="sha384-fnmOCqbTlWIlj8LyTjo7mOUStjsKC4pOpQbqyi7RrhN7udi9RwhKkMHpvLbHG9Sr" crossorigin="anonymous">
<style>
html {
font-family: Arial;
margin: 0px auto;
text-align: center;
h2 { font-size: 3.0rem; }
p { font-size: 3.0rem; }
.units { font-size: 1.2rem; }
.ds-labels{
font-size: 1.5rem;
vertical-align:middle;
padding-bottom: 15px;
</style>
</head>
<body>
<h2>Temperaturanzeige</h2>
<p>
<i class="fas fa-thermometer-half" style="color:#059e8a;"></i>
<span class="ds-labels">Temperatur Wasser</span><br>
<span id="temperaturec">%TEMPERATUREC%</span>
<sup class="units">°C</sup>
</p>
<p>
<span class="ds-labels">Temperatur Luft</span><br>
<span id="temperaturef">%TEMPERATUREC%</span>
</p>
<h2>Schalter Pumpe</h2>
%BUTTONPLACEHOLDER%
</body>
<script>function toggleCheckbox(element) {
var xhr = new XMLHttpRequest();
if(element.checked){ xhr.open("GET", "/update?relay="+element.id+"&state=1", true); }
else { xhr.open("GET", "/update?relay="+element.id+"&state=0", true); }
xhr.send();
</script>
<script>
setInterval(function ( ) {
var xhttp = new XMLHttpRequest();
xhttp.onreadystatechange = function() {
if (this.readyState == 4 && this.status == 200) {
document.getElementById("temperaturec").innerHTML = this.responseText;
xhttp.open("GET", "/temperaturec", true);
xhttp.send();
}, 5000) ; //was 10000 before
document.getElementById("temperaturef").innerHTML = this.responseText; //hani eppis gändered
xhttp.open("GET", "/temperaturef", true);
xhttp.send();
</script>
</html>)rawliteral";
//replace placeholders
String processor(const String& var){
// Replaces placeholder with DS18B20 values
//Serial.println(var);
if(var == "TEMPERATUREC"){
return temperatureC;
else if(var == "TEMPERATUREC"){
return temperatureF;
//replace Relay placeholders
else if(var == "BUTTONPLACEHOLDER"){
String buttons ="";
for(int i=1; i<=NUM_RELAYS; i++){
String relayStateValue = relayState(i);
buttons+= "</h4><label class=\"switch\"><input type=\"checkbox\" onchange=\"toggleCheckbox(this)\" id=\"" + String(i) + "\" "+ relayStateValue +"><span class=\"slider\"></span></label>";
return buttons;
return String();
// Set your Static IP address
IPAddress local_IP(192, 168, 1, 184);
// Set your Gateway IP address
IPAddress gateway(192, 168, 1, 1);
IPAddress subnet(255, 255, 0, 0);
// set up
void setup(){
//Temperatur setup
// Serial port for debugging purposes
// Start up the DS18B20 library
sensors.begin();
temperatureC = readDSTemperatureC();
temperatureF = readDSTemperatureF();
//Relay setup upper part
// Set all relays to off when the program starts - if set to Normally Open (NO), the relay is off when you set the relay to HIGH
pinMode(relayGPIOs[i-1], OUTPUT);
if(RELAY_NO){
digitalWrite(relayGPIOs[i-1], HIGH);
else{
digitalWrite(relayGPIOs[i-1], LOW);
// Configures static IP address
if (!WiFi.config(local_IP, gateway, subnet)) {
Serial.println("STA Failed to configure");
// Connect to Wi-Fi
WiFi.begin(ssid, password);
Serial.println("Connecting to WiFi");
Serial.print(".");
// Print ESP Local IP Address
// Route for root / web page
server.on("/", HTTP_GET, [](AsyncWebServerRequest *request){
request->send_P(200, "text/html", index_html, processor);
//temperature server
server.on("/temperaturec", HTTP_GET, [](AsyncWebServerRequest *request){
request->send_P(200, "text/plain", temperatureC.c_str());
server.on("/temperaturef", HTTP_GET, [](AsyncWebServerRequest *request){
request->send_P(200, "text/plain", temperatureF.c_str());
//relay server
// Send a GET request to <ESP_IP>/update?relay=<inputMessage>&state=<inputMessage2>
server.on("/update", HTTP_GET, [] (AsyncWebServerRequest *request) {
String inputMessage;
String inputParam;
String inputMessage2;
String inputParam2;
// GET input1 value on <ESP_IP>/update?relay=<inputMessage>
if (request->hasParam(PARAM_INPUT_1) & request->hasParam(PARAM_INPUT_2)) {
inputMessage = request->getParam(PARAM_INPUT_1)->value();
inputParam = PARAM_INPUT_1;
inputMessage2 = request->getParam(PARAM_INPUT_2)->value();
inputParam2 = PARAM_INPUT_2;
if(RELAY_NO){
Serial.print("NO ");
digitalWrite(relayGPIOs[inputMessage.toInt()-1], !inputMessage2.toInt());
else{
Serial.print("NC ");
digitalWrite(relayGPIOs[inputMessage.toInt()-1], inputMessage2.toInt());
// Store the time when the relay was turned on
if (getRelayState()) {
relayStartTime = millis();
else {
inputMessage = "No message sent";
inputParam = "none";
Serial.println(inputMessage + inputMessage2);
request->send(200, "text/plain", "OK");
// Start server
server.begin();
void loop(){
// temperature sensors
if ((millis() - lastTime) > timerDelay) {
lastTime = millis();
// relay loop
if (getRelayState() && (millis() - relayStartTime >= 4*60*60*1000)) {
//relayState_chat = false;
digitalWrite(relayGPIOs[0], RELAY_NO ? HIGH : LOW);
