Relay with Digispark clone
I'm using a Digispark clone to switch a 5v relay on and off from Pin 1. But it has a horrible delay. I know pin 1 is the same pin as the onboard led, could this be the problem?
Pin 2 is conected to a wire and functioning as a touch sensor that toggle the relay on and off.
May be a problem with the software, may be a problem with the sensor, i hope the relay is mounted on a board with at least a transistor to drive the relay instead of taking the current from the arduino pin.
I dont even know what clone you are talking about.
Give us more info, post your code, post the photos of which components you are using.
How are you actually switching the relay - or is it a relay module?
